Grizzly G0463 Mill "Gage"
Status Disposed
Owner Richard Sim; sold as scrap with proceeds to owner.
If it Breaks Let Richard S. know, put up an Out of Order sign.
Location Disposed
Champion N/A
wiki/tools/grizzly_x3_4-axis_cnc_mill.1785219065.txt.gz · Last modified: 2026/07/27 23:11
