Spindle Sander
The oscillating edge belt/spindle sander has 2 machines in 1 that combines edge belt and spindle sanding in a single high performance tool. It operates with rotary and oscillating motion to achieve burn-free finishes on edges, contours, faces and inside and outside curves with a tool-free conversion from belt to spindle that easily makes changes and completes multiple jobs. The spindle sander and belt/disk sander both live in the sander cart. If you see the belt/disk sander, remove the lag bolt, flip the table, and re-insert the lag bolt to switch to the spindle sander.
| Model / Serial | Ridgid EB4424 Oscillating Edge Belt/Spindle Sander |
| Status | (Operational) as of 2020-11-30 |
| Training | Read operating manual |
| Hackable | No |
| Usage Restrictions | (Anyone, Members Only, Keyholders Only, Whitelist) |
| Owner | VHS (group buy) |
| If it Breaks | tag it as out of order and post on #woodworking Slack channel or forum |
| Loan Status | Owned by VHS |
| Arrival Date | 2020-11-30 |
| Location | Woodshop (sander cart) |
| Value | $200 CAD |
| Note | Date | Who |
| Wiki entry created | Nov 20, 2013 | John C |
