Button Maker
Status Operational as of April 2019
Training Recommended so you don't waste materials
If it Breaks You'd have to make a real effort to break this. Don't drop it.
Loan Status Owned
Arrival Date Date
Location Underneath the crafting table, side closest to couches
Notes about the button maker:
  • It makes 1 1/2“ buttons
  • There is a cutter to cut out paper circles for buttons. It should be with the button maker. It's made of metal and is pretty heavy duty, about 5” square base, with a little handle to pull down and punch the circles out.
Template
Template for designing your button button_template_markup.pdf
Supplies
Button maker and button supplies are located under the craft table, near the couches. Locally Blim and Six Cent Press have parts.
wiki/tools/badge_a_minit_button_maker.1775616055.txt.gz · Last modified: 2026/04/07 19:40
