Voltron: Voron v2.4 350mm
Status Under construction
Training Mandatory (Unique to this printer)
Hackable No
Usage Restrictions See Below
If it Breaks Put a “broken” sign on machine, post to Talk with details.
Loan Status n/a
Arrival Date Jan 2024
Location 3D Printing Bench
Features
  • 350mm × 350mm × 350mm build volume
  • Mosquito Hotend with Diamondback hardened nozzle
  • Removable spring steel build plate
  • Compatible materials*: PLA, PETG, TPU
  • Wonky googly eyes
  • No Start/End gcode required
  • Automatic bed levelling and Z offset
  • (tbd) External ventilation
<wrap lo>*Not an exhaustive list; contact #3D Printer Committee by posting on Talk to request using other materials. </wrap>
Information
Added to the 3D printing stable in 2024, the Voron is VHS's first high-speed, larger size, enclosed printer. It is named Voltron, and uses the pronouns 'They/Them/It'.
Currently, it is still under construction. Once ready for members, it will require a separate training session to cover all of the info which is unique to this printer at VHS. To get training, post on Talk requesting a session.
More info will be added shortly!
Maintanance and Build Information
<hidden> MainsailOS - UI: http://mainsailos.local - SSH-U: VHS - SSH-P: VanHackVoron - Admin restricted to #3DPC only - <wrap hi>do not hack!</wrap> </hidden>
wiki/tools/voron_v2.4_voltron.1723520168.txt.gz · Last modified: 2024/08/12 20:36
