| wiki:tools:training [2026/08/26 09:59] – adheesh | wiki:tools:training [2026/10/02 11:59] (current) – uxdaniel | ||
| Line 1: | Line 1: | ||
| - | ======Requesting | + | # Tool Training |
| - | Some tools require mandatory training before use because they involve higher risks, specialized techniques, or proper setup to operate safely and effectively. Training | + | Some tools require mandatory training |
| - | We understand | + | The table below lists commonly used tools that require |
| - | ==== 3D Printers: | + | **This is not an exhaustive list.** |
| - | === FDM Printers: === | + | |
| - | Fill out [[https:// | + | |
| - | === FDM Printers Advanced (Voron/ | + | We understand that members have different levels of experience and comfort when working with tools. Please do not hesitate |
| - | === Resin Printers: === | + | |
| - | ====CNC: ==== | + | |
| - | ====Laser:==== | + | When in doubt, ask on [Slack](https://vanhack.slack.com) or [Talk](https://talk.vanhack.ca). |
| - | More details about laser training is available [[..: | + | |
| - | Fill out [[https://forms.gle/ | + | |
| - | ====Machine Shop ==== | + | For paid training sessions, a **sliding scale may be available |
Post on #machine shop on [[https:// | + | |
| - | ==== Sewing: ==== | + | | Area | Tool / Equipment | Training / Safety Orientation | Time | Cost | How to Request | Notes | |
| - | === Brother Embroidery Machine | + | | ---------------- | ------------------------------------------------------------------- | ----------------------------- | ----------- | ------------------------- | ----------------------------------------------------------------------------------------------------------------------- | ----------------------------------------------------------------------------------------------------------------------------------------------- | |
| - | | + | | **3D Printing** | FDM Printers | Required | — | — | [Request training](https:// |
| - | === Industrial Sewing Machine | + | | **3D Printing** | Advanced FDM Printers ([Voron](https:// |
| - | Post on #sewing on [[https:// | + | | **3D Printing** | Resin Printers ([Form 1](https:// |
| - | ==== Woodshop: | + | | **CNC** | Wood CNC / Metal CNC | Required | — | $100 | [Request training](https:// |
| - | Post on # | + | | **Laser** | Laser Cutter | Required | 2.5–3 hours | $30 | [Request training](https:// |
| + | | **Machine Shop** | [Mini Lathe](https:// | ||
| + | | **Machine Shop** | [Metal Lathe](https:// | ||
| + | | **Machine Shop** | [Manual Mill](https:// | ||
| + | | **Sewing** | Brother Embroidery Machine | ||
| + | | **Sewing** | Industrial Sewing Machine | ||
| + | | **Woodshop** | Planer / Jointer | Required | — | — | Ask in **# | ||
| + | | **Woodshop** | Table Saw | Required | — | — | Ask in **# | ||
| + | | **Woodshop** | Other woodworking tools | Ask if unsure | — | — | Post in **# | ||
| + | | **Welding** | Welding Shop Safety Orientation | Required | ~30 minutes | $0–20, pay what you can | Post in **# | ||
| + | | **Welding** | Member-offered MIG or TIG lesson | Required (included in lesson) | 2–3 hours | $15–100, pay what you can | Post in **# | ||
| + | ## Not sure if you need training? | ||
| + | If you are unsure whether a tool requires training, or you would simply like someone to show you how to use it safely: | ||
| + | * Ask in the relevant channel on [Slack](https:// | ||
| + | * Ask on [Talk](https:// | ||
| + | * Check the tool's wiki page for tool-specific requirements. | ||
| + | * Ask another member for help before using unfamiliar equipment. | ||
| + | When in doubt, **ask before using the tool**. | ||
| - | ==== Welding: ==== | ||
| - | Post on #welding on [[https:// | ||
