| wiki:tools:jaxen_operating [2026/10/18 18:48] – training colinl | wiki:tools:jaxen_operating [2026/10/30 23:18] (current) – colinl | ||
| Line 49: | Line 49: | ||
| The roadmap: | The roadmap: | ||
| - | * Sign up for Jaxen training | + | * Sign up for Jaxen training |
| * Study the training material on this page | * Study the training material on this page | ||
| * On your training day 1: | * On your training day 1: | ||
| Line 232: | Line 232: | ||
| ==== Recommended setups: ==== | ==== Recommended setups: ==== | ||
| + | There are infinite toolholding methods out there, but this table is handy so you know what's in the CNC cabinet! | ||
| **TODO make into table** | **TODO make into table** | ||
| Line 292: | Line 294: | ||
| For lubricating gears or parts that have high forces between them (normal to the surface that the grease is on, not sliding across): use High-pressure grease. | For lubricating gears or parts that have high forces between them (normal to the surface that the grease is on, not sliding across): use High-pressure grease. | ||
| - | Blondiehacks | + | Blondiehacks |
| https:// | https:// | ||
| Line 323: | Line 325: | ||
| - In the Toolbit selector window, you'll see all the bits loaded in the library for this FreeCAD installation. | - In the Toolbit selector window, you'll see all the bits loaded in the library for this FreeCAD installation. | ||
| - When picking a bit, be sure to check ALL properties of the bit you choose to make sure that it's what you expect! Right-click on the bit, then click " | - When picking a bit, be sure to check ALL properties of the bit you choose to make sure that it's what you expect! Right-click on the bit, then click " | ||
| + | - If creating a new bit: Chipload can be left at 0mm. Tool length generally doesn' | ||
| - The bits commonly used on Jaxen will already be in the library- it is a global list. | - The bits commonly used on Jaxen will already be in the library- it is a global list. | ||
| - Click "Add to Job" | - Click "Add to Job" | ||
| Line 342: | Line 345: | ||
| In this small tutorial, we are going to create a simple surfacing/ | In this small tutorial, we are going to create a simple surfacing/ | ||
| + | Tip: Any mentions of " | ||
| - Select the geometry of your model that will be relevant to this operation. In this case, select the face you want to surface! | - Select the geometry of your model that will be relevant to this operation. In this case, select the face you want to surface! | ||
| Line 353: | Line 358: | ||
| Engraving in FreeCad and converting to toolpaths can be tricky because the methods have changed significantly with recent updates of FreeCAD. | Engraving in FreeCad and converting to toolpaths can be tricky because the methods have changed significantly with recent updates of FreeCAD. | ||
| + | You may find more info here, but it's not super helpful: [[https:// | ||
| The following is for FreeCad 1.1 !!! | The following is for FreeCad 1.1 !!! | ||
| Line 372: | Line 379: | ||
| * Create a new VCarve operation with the button in the toolbar. The shapestring should be added to the list of base geometry in the task editor window. | * Create a new VCarve operation with the button in the toolbar. The shapestring should be added to the list of base geometry in the task editor window. | ||
| * Set the depth of the opreration to be excessively deep- it should not limit the tool depth. Depth at any given point is determined automatically. | * Set the depth of the opreration to be excessively deep- it should not limit the tool depth. Depth at any given point is determined automatically. | ||
| - | * Ensure that step-down is set appropriately- TODO need to adjust..... | + | * Ensure that step-down is set appropriately- TODO need to adjust..... |
| * Check the " | * Check the " | ||
| * Click Apply button to preview the paths of the Operation, then OK when you're done. | * Click Apply button to preview the paths of the Operation, then OK when you're done. | ||
