| wiki:tools:jaxen_operating [2026/09/30 23:32] – indentation colinl | wiki:tools:jaxen_operating [2026/10/30 23:18] (current) – colinl | ||
| Line 49: | Line 49: | ||
| The roadmap: | The roadmap: | ||
| - | * Sign up for Jaxen training. | + | * Sign up for Jaxen training |
| * Study the training material on this page | * Study the training material on this page | ||
| * On your training day 1: | * On your training day 1: | ||
| Line 232: | Line 232: | ||
| ==== Recommended setups: ==== | ==== Recommended setups: ==== | ||
| + | There are infinite toolholding methods out there, but this table is handy so you know what's in the CNC cabinet! | ||
| **TODO make into table** | **TODO make into table** | ||
| Line 258: | Line 260: | ||
| * Steel: Tap Magic | * Steel: Tap Magic | ||
| * Stainless-Steel: | * Stainless-Steel: | ||
| + | Here's a sample of different lube and chip control methods compared side-by-side: | ||
| + | The "chip clearing" | ||
| Line 275: | Line 284: | ||
| **Maintenance involves:** | **Maintenance involves:** | ||
| * Maintaining the core Grizzly Milling Machine. Refer to the original manual on lubrication practices. | * Maintaining the core Grizzly Milling Machine. Refer to the original manual on lubrication practices. | ||
| + | * Checking that limit switch brackets are tight and homing correctly (there are 3 brackets). | ||
| * Watching for stepper driver overload faults (axis stops moving until power cycle). | * Watching for stepper driver overload faults (axis stops moving until power cycle). | ||
| * Listening for noisy fans clogged with dust. | * Listening for noisy fans clogged with dust. | ||
| Line 284: | Line 294: | ||
| For lubricating gears or parts that have high forces between them (normal to the surface that the grease is on, not sliding across): use High-pressure grease. | For lubricating gears or parts that have high forces between them (normal to the surface that the grease is on, not sliding across): use High-pressure grease. | ||
| - | Blondiehacks | + | Blondiehacks |
| https:// | https:// | ||
| Line 315: | Line 325: | ||
| - In the Toolbit selector window, you'll see all the bits loaded in the library for this FreeCAD installation. | - In the Toolbit selector window, you'll see all the bits loaded in the library for this FreeCAD installation. | ||
| - When picking a bit, be sure to check ALL properties of the bit you choose to make sure that it's what you expect! Right-click on the bit, then click " | - When picking a bit, be sure to check ALL properties of the bit you choose to make sure that it's what you expect! Right-click on the bit, then click " | ||
| + | - If creating a new bit: Chipload can be left at 0mm. Tool length generally doesn' | ||
| - The bits commonly used on Jaxen will already be in the library- it is a global list. | - The bits commonly used on Jaxen will already be in the library- it is a global list. | ||
| - Click "Add to Job" | - Click "Add to Job" | ||
| Line 334: | Line 345: | ||
| In this small tutorial, we are going to create a simple surfacing/ | In this small tutorial, we are going to create a simple surfacing/ | ||
| + | Tip: Any mentions of " | ||
| - Select the geometry of your model that will be relevant to this operation. In this case, select the face you want to surface! | - Select the geometry of your model that will be relevant to this operation. In this case, select the face you want to surface! | ||
| Line 345: | Line 358: | ||
| Engraving in FreeCad and converting to toolpaths can be tricky because the methods have changed significantly with recent updates of FreeCAD. | Engraving in FreeCad and converting to toolpaths can be tricky because the methods have changed significantly with recent updates of FreeCAD. | ||
| + | You may find more info here, but it's not super helpful: [[https:// | ||
| The following is for FreeCad 1.1 !!! | The following is for FreeCad 1.1 !!! | ||
| Line 353: | Line 368: | ||
| * Adjust any other settings like scale and rotation. | * Adjust any other settings like scale and rotation. | ||
| * Return to the Part workbench. | * Return to the Part workbench. | ||
| - | * Drag and drop the ShapeString object | + | * In the left panel, Model hierarchy, check that the ShapeString object is NOT inside any Parts or Bodys. It must be at the same level as your body (it should not disappear when you collape all Bodys. If not, Drag and drop the ShapeString object |
| - | * You can now proceed | + | * Go to the CAM workbench. |
| + | * Create a new Job, or double click an existing job to edit. (It's suggested to add to an existing to reuse your Job settings). | ||
| + | * In the General tab, add your shapestring | ||
| + | * In the popup window, make sure the shapestring object is selected. It should appear under the 2D category. | ||
| + | * Close the job edit task. | ||
| + | * You must add at least one V bit to the job's tools before adding VCarve. | ||
| + | * **Now to add the VCarve Operation** | ||
| + | * Select the Shapestring object inside the model parts within the Job!! NOT the shapestring object that is part of your Part Body. | ||
| + | * Create a new VCarve operation with the button in the toolbar. The shapestring should be added to the list of base geometry in the task editor window. | ||
| + | * Set the depth of the opreration to be excessively deep- it should not limit the tool depth. Depth at any given point is determined automatically. | ||
| + | * Ensure that step-down is set appropriately- TODO need to adjust..... recommend 0.3mm for steel, can be larger for Aluminum. | ||
| + | * Check the " | ||
| + | * Click Apply button to preview the paths of the Operation, then OK when you're done. | ||
| + | * Double-check your feed rates and spindle RPMs for the tool controller that was used in the VCarve operation. | ||
| + | * Check the simulation of the Job by clicking the button in the toolbar. | ||
| + | * Click Post process. Your G-Code will be saved to the working directory where your FreeCAD file is saved! | ||
| + | * LOAD FILE in UCCNC, | ||
| + | * Proceed to the CNC setup section! | ||
| Line 567: | Line 600: | ||
| ====== Jaxen Exam ====== | ====== Jaxen Exam ====== | ||
| - | All answers to these questions are above on this page or will covered | + | All answers to these questions are above on this page or will be explained |
| - Where are three buttons you can push to stop the machine? | - Where are three buttons you can push to stop the machine? | ||
| Line 580: | Line 613: | ||
| - When doing a touch-off procedure for the Y axis, what's the formula to convert **spindle position** to **position of the workpiece edge**? | - When doing a touch-off procedure for the Y axis, what's the formula to convert **spindle position** to **position of the workpiece edge**? | ||
| - What happens if you jog the X axis all the way to the left? All the way to the right? | - What happens if you jog the X axis all the way to the left? All the way to the right? | ||
| - | - You are planning a surfacing operation in CAM. What resources can you consult to figure out a feed rate of the tool? | + | - You are planning a surfacing operation in CAM. What resources can you consult to figure out an appropriate |
