| wiki:tools:jaxen_cnc_mill [2026/09/13 22:04] – z encoder colinl | wiki:tools:jaxen_cnc_mill [2026/11/07 15:24] (current) – but colinl | ||
| Line 13: | Line 13: | ||
| | **Model** | | **Model** | ||
| - | | **Status** | + | | **Status** |
| | **Usage Restrictions** | Members with Training | | **Usage Restrictions** | Members with Training | ||
| | **Training** | | **Training** | ||
| | **User certification required** | YES - proof of successfully completing training | | **User certification required** | YES - proof of successfully completing training | ||
| - | | **Hackable** | + | | **Hackable** |
| | **Owner** | | **Owner** | ||
| | **If it Breaks** | | **If it Breaks** | ||
| Line 49: | Line 49: | ||
| * Y: 130-180mm, depending on workholding. | * Y: 130-180mm, depending on workholding. | ||
| * X: 350mm (largest part size is larger: half the width of the enclosure) | * X: 350mm (largest part size is larger: half the width of the enclosure) | ||
| - | * Z: 250mm (distance from chuck face to vice top) | + | * Z: 250mm (max distance from chuck face to vice top; you must subtract your tooling length) |
| Line 60: | Line 60: | ||
| ==== Speeds & Feeds ==== | ==== Speeds & Feeds ==== | ||
| - | Always set both cutting speed and feed rate properly to avoid tool damage and poor results. | + | See the Jaxen operating guide for details. |
| - | * You can look at the Jaxen Job Log for examples of past jobs so you get repeatable results. | + | |
| - | * There is also a tool on the Jaxen CNC PC for suggesting RPM and feed rates based on your job. Name???? | + | |
| ====== Maintenance ====== | ====== Maintenance ====== | ||
| + | For regular maintenance, | ||
| ==== ToDo List ==== | ==== ToDo List ==== | ||
| Line 74: | Line 72: | ||
| * basic door on front | * basic door on front | ||
| * tramming, squaring vice, and other mill accuracy verification procedures. | * tramming, squaring vice, and other mill accuracy verification procedures. | ||
| - | * Add encoder to Z axis, change driver to A spare or get new driver. | + | * Add encoder to Z axis, change driver to A spare or get new driver |
| **Non-Critical** | **Non-Critical** | ||
