| wiki:tools:jaxen_cnc_mill [2026/08/21 23:59] – fix table colinl | wiki:tools:jaxen_cnc_mill [2026/09/13 22:04] (current) – z encoder colinl | ||
| Line 3: | Line 3: | ||
| Jaxen is the most powerful CNC mill at VHS, capable of milling steels and other metals harder than aluminum and brass. | Jaxen is the most powerful CNC mill at VHS, capable of milling steels and other metals harder than aluminum and brass. | ||
| - | {{:tool:metal_cnc:jaxen_2026-july.jpg?600|}} | + | {{:wiki:tools:jaxen2026aug-closeup.jpg?600|}} |
| - | As of 2026 March, it is being prepared for wider member use. | + | As of 2026 September, it is being prepared for wider member use by the Metal CNC committee. |
| This is the homepage for Jaxen. Wiki pages for Jaxen: | This is the homepage for Jaxen. Wiki pages for Jaxen: | ||
| * [[jaxen_operating|Jaxen Operating Guide]] | * [[jaxen_operating|Jaxen Operating Guide]] | ||
| - | * [[jaxen_feed_speed|Jaxen | + | * [[jaxen_joblog|Jaxen |
| * [[jaxen_electrical|Jaxen Electrical Documentation]] | * [[jaxen_electrical|Jaxen Electrical Documentation]] | ||
| Line 37: | Line 37: | ||
| * **Sensors: | * **Sensors: | ||
| - | === Rigidity + Backlash === | + | === Backlash === |
| - | 2026 Mar 22 tests showed that error is less than 0.1mm, maybe 0.05mm in both the X and Y axes. | + | **As of 2026 Aug, with software backlash compensation enabled: users can expect accuracy of 0.01mm or better |
| + | Raw mechanical backlash before compensation: | ||
| + | === Rigidity === | ||
| + | To be measured... | ||
| === Max build size: === | === Max build size: === | ||
| - | * Y: ~130mm, see note below. | + | * Y: 130-180mm, depending on workholding. |
| * X: 350mm (largest part size is larger: half the width of the enclosure) | * X: 350mm (largest part size is larger: half the width of the enclosure) | ||
| * Z: 250mm (distance from chuck face to vice top) | * Z: 250mm (distance from chuck face to vice top) | ||
| - | Y axis increase plan: | ||
| - | Move the Vice mount point backwards one slot to middle slot. | ||
| - | Would also need to re-adjust the Y home position, since it likely won't reach it anymore. | ||
| - | ==== Training ==== | + | ====== Training |
| * **Mandatory training required** before use. | * **Mandatory training required** before use. | ||
| * Suggested to first complete training and certification on the [[wiki: | * Suggested to first complete training and certification on the [[wiki: | ||
| Line 59: | Line 60: | ||
| ==== Speeds & Feeds ==== | ==== Speeds & Feeds ==== | ||
| - | * Use the CNC PC’s cutting speed calculator to determine correct RPM and feed rates | + | Always set both cutting speed and feed rate properly to avoid tool damage and poor results. |
| - | * Always set both cutting speed and feed rate properly to avoid tool damage and poor results | + | * You can look at the Jaxen Job Log for examples of past jobs so you get repeatable results. |
| + | * There is also a tool on the Jaxen CNC PC for suggesting RPM and feed rates based on your job. Name???? | ||
| - | ==== Maintenance ToDo List ==== | + | ====== Maintenance |
| + | ==== ToDo List ==== | ||
| **Critical** | **Critical** | ||
| - | * Splice spindle encoder cable (or run with PID control turned off) | ||
| * Replace metal side panel with plexiglass for viewing from the workstation. | * Replace metal side panel with plexiglass for viewing from the workstation. | ||
| * basic door on front | * basic door on front | ||
| - | * tramming, and other mill accuracy verification procedures. | + | * tramming, squaring vice, and other mill accuracy verification procedures. |
| - | * software backlash compensation setup using test results and then re-test. | + | * Add encoder to Z axis, change driver to A spare or get new driver. |
| **Non-Critical** | **Non-Critical** | ||
| + | * Measure rigidity | ||
| * Increase Y axis limit by moving vice, verify new limits and update specs. | * Increase Y axis limit by moving vice, verify new limits and update specs. | ||
| * Secure XYZ hard limits better, each only held with 1 screw. | * Secure XYZ hard limits better, each only held with 1 screw. | ||
| * Isolated inputs for hardware limits appear to be pulled high by 24VDC supply, bypassing isolation and daughter multiplexing board. | * Isolated inputs for hardware limits appear to be pulled high by 24VDC supply, bypassing isolation and daughter multiplexing board. | ||
| * For custom boards inside column enclosure: Insulation on screw terminals and cable management for 120VAC connections- risk of short circuiting. | * For custom boards inside column enclosure: Insulation on screw terminals and cable management for 120VAC connections- risk of short circuiting. | ||
| + | * Add alarm monitoring of stepper drives as digital input (can monitor all in series with 1 input point) | ||
| * Make probe circuit normally closed (active low). | * Make probe circuit normally closed (active low). | ||
| * Master power switch for electrical panel. | * Master power switch for electrical panel. | ||
| Line 84: | Line 91: | ||
| * Consider spare parts for the most common things users could break, like spindle system. | * Consider spare parts for the most common things users could break, like spindle system. | ||
| * Consider systems for preventing crashes, currently only have software limits. | * Consider systems for preventing crashes, currently only have software limits. | ||
| + | * Add 2nd solid state relay to cut off power to motor drivers. | ||
| + | * Check effectiveness of spindle encoder index pin, and potentially remove to free-up IO. Since it is not actually on spindle, index is not indicating any real fixed location. | ||
| Line 90: | Line 98: | ||
| ==== Maintenance Log ==== | ==== Maintenance Log ==== | ||
| ^ Date ^ Who ^ Note | | ^ Date ^ Who ^ Note | | ||
| - | | 2026 Aug 21 | Colin L | Ground bus bar behind controller | + | | 2026 Aug 28 | Colin L | Splice spindle encoder cable, terminate, cable management, encoder PPM settings adjust. |
| - | | 2026 Aug 15 | Colin L | Cut rear enclosure panel for future | + | | 2026 Aug 21 | Colin L | Ground bus bar behind controller |
| + | | 2026 Aug 15 | Colin L | Cut another notch in rear enclosure panel for column | ||
| | 2026 Aug 14 | Colin L | E-Stop circuit troubleshooting, | | 2026 Aug 14 | Colin L | E-Stop circuit troubleshooting, | ||
| | 2026 Aug 8 | ColinL | | 2026 Aug 8 | ColinL | ||
| Line 102: | Line 111: | ||
| - | ==== History ==== | + | ====== History |
| * **Donated by:** [[https:// | * **Donated by:** [[https:// | ||
| * **Donation terms:** Purchased by VHS for $1; donor retains first right of repurchase if disposed | * **Donation terms:** Purchased by VHS for $1; donor retains first right of repurchase if disposed | ||
| Line 125: | Line 134: | ||
| {{tool: | {{tool: | ||
| + | Pic of Jaxen about 2026 July during the move into the corner and new enclosure: | ||
