wiki:tools:jaxen_cnc_mill [2026/07/28 00:27] colinlwiki:tools:jaxen_cnc_mill [2026/07/28 01:30] (current) colinl
-===== 'Jaxen' - CNC Milling Machine =====+====== 'Jaxen' - CNC Milling Machine ======
 Jaxen is the most powerful CNC mill at VHS, capable of milling steels and other metals harder than aluminum and brass. Jaxen is the most powerful CNC mill at VHS, capable of milling steels and other metals harder than aluminum and brass.
 +{{:tool:metal_cnc:jaxen_2026-july.jpg?600|}}
 As of 2026 March, it is being prepared for wider member use. As of 2026 March, it is being prepared for wider member use.
Line 54: Line 56:
 ^ Date       ^ Who        ^ Note        | ^ Date       ^ Who        ^ Note        |
 | 2026 Mar +  | ColinL  | Created new profile for metric G-Code, spindle PID loop, created workholding bed, wiring cleanup, backlash benchmarking...  | | 2026 Mar +  | ColinL  | Created new profile for metric G-Code, spindle PID loop, created workholding bed, wiring cleanup, backlash benchmarking...  |
 +| 2025 Sep  | Majicj  | Substantial documentation done on the electrical control system for the wiki.   |
 | 2016/2017  | Chris (donor)  | Disassembled after poor cut quality; discovered defective saddle, replaced with new Grizzly part, controller box rebuilt. | | 2016/2017  | Chris (donor)  | Disassembled after poor cut quality; discovered defective saddle, replaced with new Grizzly part, controller box rebuilt. |
 | 202x Jul 4   | AndroidLX   | Significant modifications performed. Machine confirmed to run UCCNC, noted as “not particularly user-friendly.” | | 202x Jul 4   | AndroidLX   | Significant modifications performed. Machine confirmed to run UCCNC, noted as “not particularly user-friendly.” |
Line 75: Line 78:
 {{tool:metal_cnc:jaxencncmill.jpeg?300|Jaxen CNC Milling Machine}} {{tool:metal_cnc:jaxencncmill.jpeg?300|Jaxen CNC Milling Machine}}
-==== CNC mill controller setup ====
-All the controller hardware is located in an electrical panel on the wall behind the mill.
-{{tool:metal_cnc:jaxencncmillcontrollerpanel.jpeg?300|NDR-480-48}}
-=== 1. Power Supplies ===
-There are four Mean Well power supplies:
-  * NDR-480-48 (x2): Provide 48V, 10A DC to the stepper/servo drivers (blue modules marked Motor Z/A and Motor X/Y).
-    *  These deliver the high-power DC that actually runs the motors.
-  * MDR-60-24: Provides 24V DC for control electronics (like relays, sensors, and logic boards).
-  * MDR-60-5: Provides 5V DC for logic-level components (controller board, encoders, or optoisolators).
-**Hookup**:
-  * AC mains (100–240V) enters at the bottom (L/N/Earth).
-  * DC outputs (+V and –V) run to the motor drivers and controller boards.
-{{tool:metal_cnc:jaxencncmillcontrollerpower1.jpeg?300|NDR-480-48}}
-{{tool:metal_cnc:jaxencncmillcontrollerpower2.jpeg?200| MDR-60-24 and MDR-60-5}}
-=== 2. Motor Drivers ===
-The blue modules marked X, Y, A, and black module Z, are stepper/servo motor drivers.
-  * Function: Convert low-level step/direction/enable signals from the controller into high-power pulses for the motors.
-  * Each axis has its own driver.
-  * Wiring:
-    *  Signal side (green connectors): Receives Step (Red), Dir (White), Ena (Green) from the motion controller.
-    *  Power side: Fed by 48V from the NDR-480 supplies.
-    *  Motor outputs: Four heavy wires going to each motor coil.
-    *  Rotary encoder inputs: see Motor (XY) Rotary Encoder Pinouts below
-**Motor (XY) Rotary Encoder Pinout**
-^ Pin # ^ Pin Label ^ Description ^ Encoder Wire Color ^
-| 1     | EB+       | Encoder B phase input + | Yellow |
-| 2     | EB-       | Encoder B phase input - | Green  |
-| 3     | EA+       | Encoder A phase input + | Black  |
-| 4     | EA-       | Encoder A phase input - | Blue   |
-| 5     | VCC       | Encoder voltage (+5V)   | Red    |
-| 6     | EGND      | Encoder ground (0V)     | White  |
-**NOTE:** Disconnected encoder wires will damage the driver and/or encoder.
-**Motor (XY) Rotary Encoder Cable Color Mapping**
-The installed 6-wire cable uses three identical black conductors. They are correctly landed on EA−, EB−, and EGND but should be labeled to avoid confusion.
-^ Pin # ^ Signal ^ Function ^ “Standard” Color (from prior table) ^ Jaxen Cable Color ^
-| 1 | EB+  | Encoder B phase input + | Yellow | **Green** |
-| 2 | EB-  | Encoder B phase input - | Green  | **Black** (label: EB−) |
-| 3 | EA+  | Encoder A phase input + | Black  | **White** |
-| 4 | EA-  | Encoder A phase input - | Blue   | **Black** (label: EA−) |
-| 5 | VCC  | Encoder supply +5 V     | Red    | **Red** |
-| 6 | EGND | Encoder ground (0 V)    | White  | **Black** (label: GND) |
-{{tool:metal_cnc: jaxencncmillcontrollermotordrivers.jpeg?300| Motor Drivers}}
-Photos of X,Y and A Servo Drivers
-{{tool:metal_cnc: jaxenhss57hybridservodriver1.jpeg?300| Motor Drivers}}
-{{tool:metal_cnc: jaxenhss57hybridservodriver2.jpeg?300| Motor Drivers}}
-{{tool:metal_cnc: jaxenhss57hybridservodriver3.jpeg?300| Motor Drivers}}
-**HSS57 Hybrid Servo Driver**
-The **HSS57** is a hybrid servo driver used to control the X and Y axis closed-loop stepper motors on the Jaxen CNC mill.
-It drives the **57HSE2N-D25 motors** with encoder feedback, ensuring reliable closed-loop operation.
-[[https://cncdrive.com/datasheets/HSS57.pdf|HSS57 driver datasheet]]
-**Device Identification**
-  * **Model**: HSS57
-  * **Type**: Hybrid Servo Driver (closed-loop stepper controller)
-  * **Voltage Range**: 24–50 VDC
-  * **Control Interface**: Step/Dir inputs
-  * **Feedback**: Encoder input (closed-loop control)
-This driver is designed for **closed-loop stepper motors** (sometimes called “servo steppers”). It prevents lost steps by correcting position via encoder feedback.
-**Connections**
-**Motor (4 terminals)**
-  * A+, A–
-  * B+, B–
-**Encoder (6 terminals)**
-  * VCC
-  * EGND
-  * EA+, EA–
-  * EB+, EB–
-**Control Inputs/Outputs (12 terminals)**
-  * ENA+, ENA– : Enable input
-  * DIR+, DIR– : Direction input
-  * PUL+, PUL– : Step pulse input
-  * ALM+, ALM– : Alarm output (fault status)
-**Pulse/Rev Table (Microstepping)**
-DIP switches SW3–SW6 set the resolution (controller pulses per motor revolution):
-X and Y currenltly set for 10000 Pulses/Rev
-^ Pulses/Rev ^ SW3 ^ SW4 ^ SW5 ^ SW6 ^
-| Default    | on  | on  | on  | on  |
-| 10000      | off | on  | off | off |
-* Lower values = coarser steps, higher speed
-* Higher values = finer steps, smoother motion, higher resolution
-** Key Features **
-  * Closed-loop stepper control with encoder feedback
-  * Prevents lost steps and provides stall detection
-  * Alarm output via ALM pins
-  * Uses standard Step/Dir interface (compatible with AXBB-E controller)
-  * Optimized for NEMA 23/24 closed-loop stepper motors
-**Summary**
-The **HSS57 Hybrid Servo Driver** controls the **X and Y axis motors** on the Jaxen CNC. Powered by the Mean Well 48V supplies, it accepts **step/dir signals** from the AXBB-E motion controller and uses encoder feedback to guarantee position accuracy. This closed-loop setup improves reliability compared to open-loop stepper drivers.
-**Photos of Z Servo Driver**
-{{tool:metal_cnc:jaxsenma860h_zdriver1.jpeg?300| Motor Drivers}}
-{{tool:metal_cnc:jaxsenma860h_zdriver2.jpeg?300| Motor Drivers}}
-{{tool:metal_cnc:jaxsenma860h_zdriver3.jpeg?300| Motor Drivers}}
-**MA860H Stepper Driver (Z axis)**
-The **MA860H** is a digital stepper motor driver used to control the **Z axis** on the Jaxen CNC mill.
-It is designed for high-torque NEMA 34 stepper motors and provides microstepping, current control, and high-voltage operation.
-[[https://www.omc-stepperonline.com/download/MA860H.pdf|MA860H driver manual (PDF)]]
-  * **Model**: MA860H
-  * **Type**: 2-phase digital stepper driver
-  * **Voltage Range**: 18–80 VAC or 24–110 VDC
-  * **Microstepping Resolution**: Up to 40,000 pulses/rev
-  * **Peak Current Output**: Up to 7.2 A
-**Connections**
-**Signal Inputs**
-  * **DIR+ / DIR–** : Direction control input
-  * **PUL+ / PUL–** : Step pulse input
-  * **ENA+ / ENA–** : Enable input
-(Inputs accept **+5V to +24V logic**.)
-**Motor Outputs**
-  * A+, A– : Motor phase A
-  * B+, B– : Motor phase B
-**Power Supply**
-  * AC ~ terminals : 18–80 VAC input
-  * DC terminals : 24–110 VDC input
-**DIP Switch Configuration**
-Your current switch settings: **SW1 = 0, SW2 = 0, SW3 = 0, SW4 = 0, SW5 = 0, SW6 = 1, SW7 = 0, SW8 = 0**
-  * **Motor Current Setting (SW1-SW3 = 000)**: **6.0 A RMS / 7.2 A peak** maximum current
-  * **Idle Current (SW4 = 0)**: **Half-current hold mode** (reduced current when idle)
-  * **Microstep Resolution (SW5-SW8 = 0100)**: **10,000 pulses/rev** (≈ 1/50 microstepping for a 1.8° stepper)
-**Key Features**
-  * High-voltage, high-current driver for large stepper motors (NEMA 34 class)
-  * Microstepping up to 1/128 (40,000 pulses/rev)
-  * Automatic idle current reduction (via SW4)
-  * Step/Dir/Enable compatible with AXBB-E motion controller
-  * Used exclusively for the **Z axis** on the Jaxen CNC
-**Summary**
-The **MA860H** powers the Z-axis stepper motor on the Jaxen CNC. It runs at **6.0 A RMS, half-current hold**, with **10,000 steps/rev microstepping**, providing smooth motion and strong holding torque. It interfaces with the AXBB-E controller via standard Step/Dir signals.
-=== 3. Ethernet Motion Controller ===
-The AXBB-E (CNCdrive) is the central brain. Pic below.
-  * Function: Interfaces between UCCNC on your PC (via Ethernet) and the motor drivers, limit switches, and I/O.
-  * Ports:
-    *  Port 1 (Isolated Outputs): Sends step/dir/ena signals to the motor drivers.
-    *  Port 2 (Isolated Inputs): Reads signals from limit switches, homing switches, estop, etc.
-    *  Port 3 (Non-Isolated Inputs/Outputs): General-purpose inputs/outputs.
-    *  24V/5V Power In: Supplied from the Mean Well MDR units.
-  * Status LEDs show link, power, and I/O states.
-[[https://www.cncdrive.com/downloads/AXBB_E_manual.pdf|AXBB-E Controller and Breakout Board Users Guide]]
-{{tool:metal_cnc:jaxencncmillmotioncontroller.jpeg?300| AXBB-E (CNCdrive) Ethernet Motion Controller}}
-=== 4. UCSB Breakout and I/O Board ===
-The smaller green PCB to connected to left of Ethernet Motion Controller(near orange terminal blocks):
-  * Expands I/O from the AXBB-E.
-  * Provides screw terminals for clean connection of inputs (limit switches, probe, estop) and outputs (coolant pump, spindle relay, etc.).
-  * Optoisolated for noise protection.
-{{tool:metal_cnc:jaxencncmillcontrollerbreakout_io_board.jpeg?300| Breakout I/O Board}}
-Example setup of Ethernet Controller and Breakout I/O Board
-{{tool:metal_cnc:axbb-e_5.png?500| Example Setup Motion Controller and Breakout Board}}
-=== 5. Motors ===
-Jaxen Mill (Grizzly + King base) uses stepper motors on X, Y, Z. There is a fourth driver 'A', that could run a rotary or 4th axis. These receive power and control via the drivers.
-**X and Y axis Motors**
-{{tool:metal_cnc:jaxencncxymotors1.jpeg?300| XY Closed loop stepper motors}}
-{{tool:metal_cnc:jaxencncxymotors2.jpeg?300| XY Closed loop stepper motors}}
-** XY Motor Identification**
-  * Model: 57HSE2N-D25
-  * Type: Hybrid stepper motor with integrated encoder
-  * Manufacturer: JSS Motor (as labeled on the tag: “JSS MOTOR NO:201701”)
-** XY Motor Leads**
-  * The motor side has the usual 4-lead bipolar wiring:
-  * A+ = Red
-  * A- = Green
-  * B+ = Yellow
-  * B- = Blue
-This means it’s a 2-phase, bipolar stepper.
-** XY Encoder Leads**
-  * The encoder provides feedback for closed-loop control:
-  * EA+ = Black
-  * EA- = Blue
-  * EB+ = Yellow
-  * EB- = Green
-  * VCC = Red (supply power for encoder, usually 5 V)
-  * EGND = White (encoder ground)
-**Typical Wiring Diagram**
-{{tool:metal_cnc:typicalwiringdiagram.png?600| Typical Wiring Diagram}}
-This is a standard quadrature encoder setup (channels A and B), giving the controller both position and direction feedback.
-** XY Typical Specifications (based on 57HSE2N series)**
-While exact numbers vary slightly by supplier, the 57HSE2N-D25 generally matches:
-^ Attribute          ^ Value (typical)                                        ^
-| Frame Size         | NEMA 23 (57 mm)                                        |
-| Step Angle         | 1.8° (200 steps/rev)                                   |
-| Holding Torque     | ~2.0–2.5 Nm (280–350 oz-in)                            |
-| Rated Current      | ~4.0–5.0 A/phase                                       |
-| Resistance         | ~0.5–0.8 Ω/phase                                       |
-| Inductance         | ~2.5–4.0 mH                                            |
-| Encoder Resolution | 1000–2500 PPR (typical, quadrature)                    |
-| Voltage Drive      | 48 V DC (as supplied by your Mean Well NDR-480-48 PSU) |
-  * XY axis are closed-loop stepper motors—sometimes marketed as servo-stepper hybrids—which combine the simplicity of stepper drive with the position assurance of encoder feedback.
-**Function in Your CNC (Jaxen)**
-  * X Axis Motor: Moves the table left/right (long axis).
-  * Y Axis Motor: Moves the table front/back (short axis).
-  * Both motors receive step/dir signals from the CNCdrive AXBB-E motion controller via the blue motor drivers you showed earlier.
-The encoders feed back position to the drivers, enabling stall detection and correction, preventing lost steps.
-**Z Axis Motor not documented**
-**Summary:**
-The 57HSE2N-D25 motors on your Grizzly/Jaxen CNC are NEMA 23 closed-loop stepper motors with encoders. They provide about 2–2.5 Nm torque, run at ~4–5 A/phase, and are driven by your 48 V Mean Well PSU through dedicated stepper drivers. Their integrated encoders make the system far more reliable than open-loop steppers.
-=== 7. Limit Switches and RJ-11 Breakout Board ===
-**Limit Switch Configuration**
-Jaxen CNC uses **one limit switch per axis** (X, Y, Z). Each switch is mounted at the **home end of travel** for its axis.
-UCCNC manages the opposite end of travel via **soft limits**. If any limit switch is triggered during machining, motion stops immediately on all axes.
-**Physical Layout**
-  * **X Axis** → Limit switch at the X− end (left side when facing the machine).
-  * **Y Axis** → Limit switch at the Y− end (front of the table).
-  * **Z Axis** → Limit switch at the Z+ end (top of spindle travel).
-Each switch is wired into the controller as both a **homing switch** and a **limit switch**.
-**Function in UCCNC**
-  * During homing, the axis moves toward the limit switch until it triggers, then backs off to establish machine zero.
-  * During normal operation, the same switch acts as a hardware limit in that direction.
-  * The opposite end of travel is protected using **software soft limits**, defined in UCCNC machine setup.
-{{tool:metal_cnc:jaxenlimitswitches_x.jpeg?300| X Minus Limit Switch}}
-{{tool:metal_cnc:jaxenlimitswitches_y.jpeg?300| Y Minus Limit Switch}}
-{{tool:metal_cnc:jaxenlimitswitches_z.jpeg?200| Z Minus Limit Switch}}
-These limit switches are connected through a dedicated **Creltek RJ-11 Sensor Breakout Board v2.1** for safety and homing. This board consolidates up to 8 limit switch inputs into RJ-11 connectors, making wiring cleaner and reducing electrical noise from motors and power electronics.
-  * Each axis (X, Y, Z) has independent limit switches routed through the breakout board.
-  * Output signals can be **wire-OR’d**, allowing multiple switches per axis if needed.
-  * The breakout board is wired into the **AXBB-E motion controller**.
-  * Designed for **reliability in CNC environments** with high electrical interference.
-  * Creltek Datasheet: [[https://d3s5r33r268y59.cloudfront.net/datasheets/6257/2017-07-26-15-29-56/Creltek%20RJ11%20Sensor%20Breakout%20v2.1%20Datasheet.pdf|Creltek RJ-11 Sensor Breakout v2.1 Datasheet]]
-^ Feature              ^ Description        ^
-| **Name**             | Creltek RJ-11 Sensor Breakout Board v2.1 (by Kevin H. Patterson)             |
-| **Connectors**       | 8 × RJ-11 jacks (each with power, ground, and signal)                       |
-| **Outputs**          | Active-low, open-collector, capable of sinking >200 mA                      |
-| **Pull-ups**         | Optional on-board 4.7 kΩ pull-up resistors                                  |
-| **Noise Filtering**  | Built-in circuitry for robust operation in electrically noisy environments  |
-| **Voltage Support**  | Native 3.3 V, or 5–18 V with onboard regulator                              |
-| **Mounting**         | Panel-mount capable; designed for professional installation                 |
-{{tool:metal_cnc:jaxenlimitswitchboard1.jpeg?300| Creltek Limit RJ-11 Switch Board}}
-{{tool:metal_cnc:jaxenlimitswitchboard2.jpeg?300| Creltek Limit RJ-11 Switch Board}}
-{{tool:metal_cnc:jaxenlimitswitcheboard3.jpeg?200| Creltek Limit RJ-11 Switch Board}}
-=== 8. Spindle Feedback Encoder ===
-The spindle position and speed are monitored using a **rotary encoder** mounted at the top of the spindle assembly.
-{{tool:metal_cnc: jaxenrotaryencodertop.jpeg?300| Rotary Encoder on Top of Jaxen}}
-{{tool:metal_cnc:jaxen_rotary_encoder_e38s6g5-600z.png?300| Spindle Feedback Rotary Encoder}}
-  * **Model**: E38S6G5-600Z
-  * **Type**: Incremental rotary encoder
-  * **Body size**: 38 mm diameter
-  * **Mounting**: Solid shaft, direct-coupled to spindle
-**Specifications**
-  * **Resolution**: 600 pulses per revolution (P/R)
-  * **Channels**: A, B (quadrature) + Z (index pulse, 1 per revolution)
-  * **Supply voltage**: 5–24 VDC
-  * **Output type**: Line driver / push-pull TTL (depending on wiring)
-  * **Shaft**: Solid, 6 mm or 8 mm diameter (variant dependent)
-  * **Output signals**: Differential A, B, Z for accurate detection
-**Function**
-  * Provides real-time spindle speed feedback to the motion controller (AXBB-E).
-  * Index pulse (Z) can be used for precise synchronization tasks:
-    * Rigid tapping
-    * Thread cutting
-    * Accurate spindle homing
-**Role in Jaxen CNC**
-The encoder ensures that the control system knows the **actual spindle RPM** and **rotational position**.
-This allows for advanced machining operations where tool motion must be precisely synchronized with spindle rotation.
-**References**
-  * [[https://www.tenettech.com/product/pro-range-e38s6g5-600z-g24n-rotary-incremental-encoder-38mm-photoelectric-abz-3-channels-600-ppr|Example Rotary Encoder]]
-=== 9. Spindle Control Board ===
-https://www.yumpu.com/en/document/read/24635331/cnc-spindle-control-upgrade-kit-little-machine-shop
-=== 10. E-Stop ===
-tbd
-=== 11. Tool Offset Sensor ===
-**MY20-20-2 CNC Automatic Tool Sensor Gauge**
-{{tool:metal_cnc:tooltouchoffsensor1.jpeg?200| Tool Offset Sensor Gauge}}
-^ **Parameter**              ^ **Specification** ^
-| Model                       | MY20-20-2 |
-| Type                        | Automatic tool setter / touch sensor |
-| Operating voltage           | 24 VDC (nominal, 5–24 V compatible) |
-| Contact type                | Normally Closed (NC) |
-| Construction                | Anodized aluminum body, carbide plunger |
-| Plunger travel              | ~2 mm (spring loaded) |
-| Repeatability               | ±0.001 mm |
-| Output signal               | Switch closure (opens on touch) |
-| Wiring                      | 2-wire NC switch: +24 V → sensor → AXBB-E input (I±) |
-| Recommended AXBB-E input    | Isolated input (e.g. I6+ / I6-) |
-| UCCNC configuration         | Assign as **Probe input** |
-| Application                 | Automatic tool length offset, tool change probing |
-| Notes                       | Wire as NC for fail-safe; if cable breaks, UCCNC sees an open input (probe tripped). |
-=== 12. PC & UCCNC Software ===
-  * [[https://www.cncdrive.com/UCCNC.html|UCCNC]] software (Windows 10) generates the motion control stream.
-  * Sends commands (steps/directions) over Ethernet to the AXBB-E.
-  * The AXBB-E translates them into hardware pulses for the drivers.
-  * Operator inputs (limit switches, estop, spindle control) feed back to UCCNC via the AXBB-E.
-=== Signal Flow Summary ===
-  * Mains AC → Power Supplies → Provide 48V (motors), 24V (control), 5V (logic).
-  * PC running UCCNC → Ethernet → AXBB-E Motion Controller.
-  * AXBB-E Outputs → Step/Dir/Ena → Motor Drivers (X, Y, Z, A).
-  * Motor Drivers → High-voltage pulses → Stepper Motors.
-  * AXBB-E Inputs ← Limit switches, estop, home sensors.
-  * Optional: Outputs control spindle, coolant, etc.
