wiki:tools:bernie_the_spindle_sander [2020/11/30 11:00] – created - external edit 127.0.0.1wiki:tools:bernie_the_spindle_sander [2026/02/22 15:05] (current) andrew_m
-====== Name of Tool ====== +====== Spindle Sander======
-{{::generic-tool.png?200|}}+{{:wiki:tools:spindle_sander.jpeg?400|}}
-The oscillating edge belt/spindle sander has 2 machines in 1 that combines edge belt and spindle sanding in a single high performance tool. It operates with rotary and oscillating motion to achieve burn-free finishes on edges, contours, faces and inside and outside curves with a tool-free conversion from belt to spindle that easily makes changes and completes multiple jobs.+The oscillating edge belt/spindle sander has 2 machines in 1 that combines edge belt and spindle sanding in a single high performance tool. It operates with rotary and oscillating motion to achieve burn-free finishes on edges, contours, faces and inside and outside curves with a tool-free conversion from belt to spindle that easily makes changes and completes multiple jobs.
 +The spindle sander and belt/disk sander both live in the sander cart. If you see the belt/disk sander, remove the lag bolt, flip the table, and re-insert the lag bolt to switch to the spindle sander.
 ^ Model / Serial     | Ridgid EB4424 Oscillating Edge Belt/Spindle Sander                      | ^ Model / Serial     | Ridgid EB4424 Oscillating Edge Belt/Spindle Sander                      |
Line 13: Line 15:
 ^ Loan Status        | Owned by VHS                  | ^ Loan Status        | Owned by VHS                  |
 ^ Arrival Date       | 2020-11-30        | ^ Arrival Date       | 2020-11-30        |
-^ Location           Wood Shop                                    |+^ Location           Woodshop (sander cart)                               |
 ^ Value              | $200 CAD        | ^ Value              | $200 CAD        |
