tool:smd_reflow_oven
Both sides previous revisionPrevious revision | Last revisionBoth sides next revision | ||
tool:smd_reflow_oven [2021/07/15 19:08] – packetbob | tool:smd_reflow_oven [2021/07/15 19:09] – packetbob | ||
Line 62: | Line 62: | ||
12) Once the oven has cooled to 100C the oven screen will say it is OK to remove your PCB Note that you need to use tweezers as the boards will be hot… Really really hot… Like burn your friggin fingers even though you should know better hot... | 12) Once the oven has cooled to 100C the oven screen will say it is OK to remove your PCB Note that you need to use tweezers as the boards will be hot… Really really hot… Like burn your friggin fingers even though you should know better hot... | ||
tool/smd_reflow_oven.txt · Last modified: 2021/07/15 19:09 by packetbob
