tool:relsew4000sw
tool:relsew4000sw [2019/10/04 21:04] – created dbynoe | tool:relsew4000sw [2022/06/12 21:28] (current) – elizabot | ||
- | ===== Reliable Sewing Machines 4000SW walking foot ===== | + | ====== Reliable Sewing Machines 4000SW walking foot ====== |
- | The don't mess around & will sew darn near anything industrial machine. It will happily sew leather, canvas, denim, and other thick materials. | + | The don't-mess-around & will-sew-darn-near-anything industrial machine. It will happily sew leather, canvas, denim, bike tires, and other thick materials. Also your fingers. |
- | ====Training==== | + | ====Quick facts ==== |
- | In person training | + | |
+ | ^ Usage Restrictions | Authorized and trained members only | | ||
+ | ^ Value | $$$$ | | ||
+ | =====Training===== | ||
+ | Please | ||
Training Notes: | Training Notes: | ||
- | **Turning the machine on** | + | ====Main Hazards==== |
+ | * The motor is very powerful and has a lot of inertia. It can go through the bone of your finger, and WHEN YOU TURN OFF THE MACHINE THE MOTOR REMAINS SPINNING FOR SEVERAL MINUTES. If the foot pedal is accidentally pressed while the motor is still spinning, the machine will run. Exercise caution while threading the machine. (see below) | ||
+ | ====Turning the machine on==== | ||
* The power switch is located on the underside of the table on the right hand side | * The power switch is located on the underside of the table on the right hand side | ||
- | * Turning on the power switch will cause the motor to turn on at full speed | + | * Turning on the power switch will cause the motor to turn on at full speed. It is very quiet. |
* The machine will not move until the foot pedal engages the clutch - unlike a domestic sewing machine it is not necessary (or advised) to fully depress the foot pedal to get started | * The machine will not move until the foot pedal engages the clutch - unlike a domestic sewing machine it is not necessary (or advised) to fully depress the foot pedal to get started | ||
* Due to inertia the motor will continue to spin for several minutes after being turned off, this could result in unexpected movement of the machine - **DO NOT REST YOUR FEET ON THE FOOT PEDAL WHEN THREADING THE MACHINE.** | * Due to inertia the motor will continue to spin for several minutes after being turned off, this could result in unexpected movement of the machine - **DO NOT REST YOUR FEET ON THE FOOT PEDAL WHEN THREADING THE MACHINE.** | ||
* To render the machine safe, it is best practice to turn off the power to the motor, remove your workpiece from the machine, then press and hold the foot pedal until the machine stops moving. | * To render the machine safe, it is best practice to turn off the power to the motor, remove your workpiece from the machine, then press and hold the foot pedal until the machine stops moving. | ||
- | **Knee Lift Presser foot** | + | ====Knee Lift Presser foot==== |
* The presser foot for this machine is controlled by the knee lever beside your right knee, move it to the right to lift the foot. There is also a secondary presser foot lift located in the normal position at the back of the machine. | * The presser foot for this machine is controlled by the knee lever beside your right knee, move it to the right to lift the foot. There is also a secondary presser foot lift located in the normal position at the back of the machine. | ||
- | **Adjusting Stitch Length** | + | ====Adjusting Stitch Length==== |
* To adjust stitch length, slightly depress the reverse lever (the big bar located just below the stitch length dial) and turn the stitch length knob. **Do not turn the knob more than one rotation.** | * To adjust stitch length, slightly depress the reverse lever (the big bar located just below the stitch length dial) and turn the stitch length knob. **Do not turn the knob more than one rotation.** | ||
- | **Winding a bobbin** | + | ====Winding a bobbin==== |
- Pass the thread through the thread guide then around the tension discs (located on the table just below the thread holder) | - Pass the thread through the thread guide then around the tension discs (located on the table just below the thread holder) | ||
- Install the bobbin onto the winder located in front of the belt on the right side of the machine | - Install the bobbin onto the winder located in front of the belt on the right side of the machine | ||
- | - Remove the needle from the machine | + | - Remove the needle from the machine |
- | - Push the bobbin winder rearwards until it snaps into place against the belt | + | - Push the bobbin winder rearwards until |
+ | - it snaps into place against the belt | ||
- Turn on the machine, and hold the foot pedal down until the bobbin automatically disengages from the belt. | - Turn on the machine, and hold the foot pedal down until the bobbin automatically disengages from the belt. | ||
+ | ====Oiling==== | ||
====Threading==== | ====Threading==== | ||
+ | [[tool: | ||
+ | **DO NOT REST YOUR FEET ON THE FOOT PEDAL WHEN THREADING THE MACHINE.** | ||
Follow this handy diagram! | Follow this handy diagram! | ||
- | ====Quick facts ==== | ||
- | ^ Status | ||
- | ^ Training | ||
- | ^ Hackable | ||
- | ^ Usage Restrictions | Authorized and trained members only | | ||
- | ^ Owner | David Bynoe| | ||
- | ^ If it Breaks | ||
- | ^ Loan Status | ||
- | ^ Location | ||
- | ^ Value | $$$$ | | ||
- | ^ Champion | ||
====Manual ==== | ====Manual ==== | ||
- | [[https:// | ||
tool/relsew4000sw.txt · Last modified: 2022/06/12 21:28 by elizabot
