tool:redsail_cm1080_laser_cutter [2019/02/25 03:14] – enquire | tool:redsail_cm1080_laser_cutter [2024/04/16 04:48] (current) – Added stepper driver details ddq | ||
Line 6: | Line 6: | ||
Line 17: | Line 17: | ||
Line 27: | Line 28: | ||
- **Wear the Laser safety glasses at all times.** | - **Wear the Laser safety glasses at all times.** | ||
- **Operator must remain within 1m of the machine and monitor cutting at all times when the machine is in operation.** | - **Operator must remain within 1m of the machine and monitor cutting at all times when the machine is in operation.** | ||
- | - **Only | + | - **Only |
Failure to follow these rules may result in immediate loss of Laser Cutter priviledges. | Failure to follow these rules may result in immediate loss of Laser Cutter priviledges. | ||
Line 41: | Line 42: | ||
* Type: CO2 | * Type: CO2 | ||
- | * Controller: [[http://www.lightobject.com/ | + | * Controller: [[https:// |
- | * Chiller: [[http://vanhack.ca/doku.php? | + | * Chiller: [[https://lightobject.com/q800-water-chiller/|LightObject Industrial Water Chiller Q800]], [[https:// |
* Power supply: [[http:// | * Power supply: [[http:// | ||
* Input: AC 220V | * Input: AC 220V | ||
Line 51: | Line 52: | ||
* 3pin terminal pinout: G, AC, AC | * 3pin terminal pinout: G, AC, AC | ||
* 6pin terminal pinout: H, L, WP, G, IN, 5V | * 6pin terminal pinout: H, L, WP, G, IN, 5V | ||
+ | * Input: DC 40V | ||
+ | * Motor current: 4A | ||
+ | * Steps/rev: 5000 | ||
+ | * Idle current: half | ||
- | ===== Maintentance Log ===== | + | ===== Usage and Maintenance |
===== Further Information ===== | ===== Further Information ===== | ||
Line 60: | Line 70: | ||
- | * [[tool: | ||
tool/redsail_cm1080_laser_cutter.1551064464.txt.gz · Last modified: 2019/02/25 03:14 by enquire
