tool:redsail_cm1080_laser_cutter [2015/10/17 00:21] – jarrett | tool:redsail_cm1080_laser_cutter [2024/04/16 04:48] (current) – Added stepper driver details ddq | ||
Line 10: | Line 12: | ||
Line 27: | Line 40: | ||
+ | * Input: AC 220V | ||
+ | * Current: 32mA max | ||
+ | * Input: DC 40V | ||
+ | * Motor current: 4A | ||
+ | * Steps/rev: 5000 | ||
+ | * Idle current: half | ||
+ | ==== Tutorials ==== | ||
+ | * [[tutorials: | ||
- | | Laser cutter alignment out, laser cutter requires clean | July 7, 2014 | LCC [Butters] | | + | |
- | | disassembled ventilation system - cleaned fan intake. vacuumed inside of main filter. | + | |
- | | Filter Bag Replaced, ventilation still not adequate. laser out-of-order until 2014-02-05 | + | |
- | | FIXED: Filter Bag Replaced, Y-Axis Repaired, Cutter Windows Cleaned| Dec 11, 2013 | LCC [Butters & Richard] | | + | |
- | | FIXED: Red alignment laser re-broken. Re-Soldered, | + | |
- | | FIXED: Red alignment laser is broken. Re-Soldered, | + | |
- | | Note: red alignment laser is broken. Does not affect performance of laser cutter. | Nov 23, 2013 | LCC [fishboy51] | | + | |
- | | Aligned and cleaned mirrors | Nov 23, 2013 | LCC [fishboy51] | | + | |
- | | Fixed by LCC. | Nov 22, 2013 | LCC | | + | |
- | | Exhaust fan is broken | + | |
tool/redsail_cm1080_laser_cutter.1445041303.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
