tool:redsail_cm1080_laser_cutter [2019/04/04 18:44] – 00739 | tool:redsail_cm1080_laser_cutter [2019/12/11 23:41] – The materials being cut should not be lasing. thovthe | ||
Line 28: | Line 28: | ||
- **Wear the Laser safety glasses at all times.** | - **Wear the Laser safety glasses at all times.** | ||
- **Operator must remain within 1m of the machine and monitor cutting at all times when the machine is in operation.** | - **Operator must remain within 1m of the machine and monitor cutting at all times when the machine is in operation.** | ||
- | - **Only | + | - **Only |
Failure to follow these rules may result in immediate loss of Laser Cutter priviledges. | Failure to follow these rules may result in immediate loss of Laser Cutter priviledges. | ||
Line 56: | Line 56: | ||
===== Further Information ===== | ===== Further Information ===== |
tool/redsail_cm1080_laser_cutter.txt · Last modified: 2024/04/16 04:48 by ddq
