tool:redsail_cm1080_laser_cutter [2017/10/05 17:51] – jdmc | tool:redsail_cm1080_laser_cutter [2024/04/11 14:38] – Updated chiller model ddq | ||
Line 15: | Line 17: | ||
Line 25: | Line 28: | ||
- **Wear the Laser safety glasses at all times.** | - **Wear the Laser safety glasses at all times.** | ||
- **Operator must remain within 1m of the machine and monitor cutting at all times when the machine is in operation.** | - **Operator must remain within 1m of the machine and monitor cutting at all times when the machine is in operation.** | ||
- | - **Only | + | - **Only |
Failure to follow these rules may result in immediate loss of Laser Cutter priviledges. | Failure to follow these rules may result in immediate loss of Laser Cutter priviledges. | ||
===== Laser Cutter Training ===== | ===== Laser Cutter Training ===== | ||
- | Anyone who wishes to use the laser cutter must be both a VHS member, and have completed VHS Laser Cutter Training. | + | Anyone who wishes to use the laser cutter must be both a VHS member, and have completed |
Class dates are announced on [[http:// | Class dates are announced on [[http:// | ||
- | If you are planning to take a class, please first read through [[tool: | ||
Line 39: | Line 40: | ||
- | * Controller: [[http://www.lightobject.com/ | + | * Controller: [[https:// |
- | * Chiller: [[http://vanhack.ca/doku.php? | + | * Chiller: [[https://lightobject.com/q800-water-chiller/|LightObject Industrial Water Chiller Q800]], [[https:// |
* Power supply: [[http:// | * Power supply: [[http:// | ||
* Input: AC 220V | * Input: AC 220V | ||
Line 51: | Line 53: | ||
* 6pin terminal pinout: H, L, WP, G, IN, 5V | * 6pin terminal pinout: H, L, WP, G, IN, 5V | ||
- | ===== Maintentance Log ===== | + | ===== Usage and Maintenance |
===== Further Information ===== | ===== Further Information ===== | ||
* [[committees: | * [[committees: | ||
- | * [[tool: | ||
- | * [[tool: | ||
Line 68: | Line 74: | ||
* [[tutorials: | * [[tutorials: | ||
- | * [[http:// | + | * [[http:// |
tool/redsail_cm1080_laser_cutter.txt · Last modified: 2024/04/16 04:48 by ddq
