tool:redsail_cm1080_laser_cutter [2013/11/21 19:34] – jarrett | tool:redsail_cm1080_laser_cutter [2019/12/11 23:41] – The materials being cut should not be lasing. thovthe | ||
- | Summary description of the tool and perhaps some misc notes about it's existence! | + | ---- |
- | ^ Status | + | Everybody loves lasers |
+ | * Controller: [[http:// | ||
+ | * Chiller: [[http:// | ||
+ | * Input: AC 220V | ||
+ | * Current: 32mA max | ||
+ | ==== Tutorials ==== | ||
+ | * [[tutorials: | ||
tool/redsail_cm1080_laser_cutter.txt · Last modified: 2024/04/16 04:48 by ddq
