tool:redsail_cm1080_laser_cutter [2013/11/21 19:32] – jarrett | tool:redsail_cm1080_laser_cutter [2019/04/04 18:45] – 00739 | ||
- | ====== Laser Cutter ====== | + | ====== |
- | Summary description of the tool and perhaps some misc notes about it's existence! | + | ---- |
- | ^ Status | + | Everybody loves lasers |
+ | - **Only lase Approved Materials.** | ||
+ | * Controller: [[http:// | ||
+ | * Chiller: [[http:// | ||
+ | * Input: AC 220V | ||
+ | * Current: 32mA max | ||
+ | ==== Tutorials ==== | ||
+ | * [[tutorials: | ||
tool/redsail_cm1080_laser_cutter.txt · Last modified: 2024/04/16 04:48 by ddq
