tool:pressure_chamber
Next revision | Previous revisionLast revisionBoth sides next revision | ||
tool:pressure_chamber [2016/04/15 20:34] – created michael_taylor | tool:pressure_chamber [2016/04/15 20:37] – michael_taylor | ||
- | Pressure | + | ====== |
+ | located in the machine shop on the large shelf. It's a modified paint pot and so has several valves that have been added to give a proper seal. Use the large red air compressor to pressurize. | ||
[[https:// | [[https:// | ||
#1 rule is to ALWAYS keep all clamps tightly closed while the chamber has ANY pressure inside of it, explosive decompression WILL kill you. | #1 rule is to ALWAYS keep all clamps tightly closed while the chamber has ANY pressure inside of it, explosive decompression WILL kill you. |
tool/pressure_chamber.txt · Last modified: 2019/04/06 23:00 by 00739
