tool:pressure_chamber
tool:pressure_chamber [2016/04/15 20:37] – michael_taylor | tool:pressure_chamber [2019/04/06 23:00] (current) – 00739 | ||
====== Pressure Chamber ====== | ====== Pressure Chamber ====== | ||
- | located in the machine shop on the large shelf. It's a modified paint pot and so has several valves that have been added to give a proper seal. Use the large red air compressor to pressurize. | ||
- | [[https:// | + | ^ Status |
+ | ^ Usage Restrictions | (Anyone, Members Only, Keyholders Only, Whitelist) | ||
+ | ^ Owner | (VHS or Name of proper owner) | ||
+ | ^ Arrival Date | Date | | ||
+ | ^ Value | $$ | | ||
+ | ===== Safety ===== | ||
#1 rule is to ALWAYS keep all clamps tightly closed while the chamber has ANY pressure inside of it, explosive decompression WILL kill you. | #1 rule is to ALWAYS keep all clamps tightly closed while the chamber has ANY pressure inside of it, explosive decompression WILL kill you. | ||
+ | ===== Specifications ===== | ||
+ | It's a modified paint pot and so has several valves that have been added to give a proper seal. Use the large red air compressor to pressurize. | ||
+ | ===== Tutorial ===== | ||
tool/pressure_chamber.txt · Last modified: 2019/04/06 23:00 by 00739
