tool:norseman_drill_bit_set
tool:norseman_drill_bit_set [2019/04/08 20:08] – 00739 | tool:norseman_drill_bit_set [2019/04/08 20:22] (current) – 00739 | ||
====== Norseman Drill Bits ====== | ====== Norseman Drill Bits ====== | ||
- | ^ Model / | + | ^ Model / Serial |
^ Status | ^ Status | ||
- | ^ Usage Restrictions | Members Only, Keyholders Only, Whitelist) | + | ^ Usage Restrictions | Anyone |
^ Owner | John Craver | ^ Owner | John Craver | ||
^ Arrival Date | June 2010 | | ^ Arrival Date | June 2010 | | ||
^ Value | $75 | | ^ Value | $75 | | ||
- | * **owner** = John Craver (VHS members are welcome to use these drill bits whenever they want to) | ||
- | * **user certification required** = Must be able to use a drilling machine well. | ||
- | * **hackable** = No (See tips below) | ||
- | * **model** = Norseman Black and Gold | ||
- | * **serial #** = | ||
- | * **arrived** = June 2010 | ||
- | * **does it work?** = Works | ||
- | * **if it breaks** = Go to Summit Tools in Burnaby and buy a replacement bit, or contact John. | ||
- | * **contact** = John Craver | ||
- | * **where** = Black Metal Case stuck with magnets to the Drill Press' column. | ||
- | * **value** = $75 | ||
tool/norseman_drill_bit_set.1554754113.txt.gz · Last modified: 2019/04/08 20:08 by 00739
