tool:heat_treating_oven
tool:heat_treating_oven [2022/01/18 06:53] – created mike | tool:heat_treating_oven [2023/07/10 01:41] (current) – majicj | ||
Line 9: | Line 9: | ||
* **arrived** = 2021 | * **arrived** = 2021 | ||
* **does it work?** = Works | * **does it work?** = Works | ||
- | * **if it breaks** = Unplug machine, put a "broken& | + | * **if it breaks** = Unplug machine, put a broken sign on machine, post on Talk. |
* **contact** = Machine Shop/ | * **contact** = Machine Shop/ | ||
* **where** = Machine shop | * **where** = Machine shop | ||
* **value** = $$$$ | * **value** = $$$$ | ||
Line 27: | Line 31: | ||
* If working with a buddy is not viable, consider working when others are within earshot. | * If working with a buddy is not viable, consider working when others are within earshot. | ||
===== Controls ===== | ===== Controls ===== |
tool/heat_treating_oven.1642488787.txt.gz · Last modified: 2022/01/18 06:53 by mike
