tool:battery_spot_welder
no way to compare when less than two revisions
— | tool:battery_spot_welder [2020/10/02 12:50] (current) – created brian_stubbs | ||
+ | ====== Battery Spot Welder ====== | ||
+ | Small portable battery spot welder used for making custom battery packs and replacing old cells. | ||
+ | ^ Model / Serial | ||
+ | ^ Owner | VHS | | ||
+ | ^ Arrival Date | 01Oct2020 | ||
+ | ^ Value | $300 | | ||
+ | ===== Safety ===== | ||
+ | Be careful anytime you are working with new or used battery packs. | ||
+ | Only charge the provided spot welder Lipo battery with the self balancing charger provided in the kit. | ||
+ | Use common hygiene when using spot welder: | ||
+ | * make sure surfaces are clean | ||
+ | * do not spot weld wet or oily surfaces | ||
+ | * a few small sparks may be created so make sure you don't spot weld on top of dryer lint | ||
+ | ===== Specifications ===== | ||
+ | ===== Tutorial ===== | ||
+ | ===== Maintenance Log ==== | ||
+ | ^ Note ^ Date ^ Who ^ | ||
+ | | Tool donated |
tool/battery_spot_welder.txt · Last modified: 2020/10/02 12:50 by brian_stubbs
