tool:pressure_chamber
Pressure Chamber
Status | (Unknown, Operational, Offline, ) as of Date |
Training | Optional, Recommended, Mandatory |
Hackable | YES or NO |
Usage Restrictions | (Anyone, Members Only, Keyholders Only, Whitelist) |
Owner | (VHS or Name of proper owner) |
If it Breaks | (Panic procedure, usually involving emailing list and “broken” sign) |
Loan Status | (Unknown, Owned, Permanent, Temporary, Semi-Permanent |
Arrival Date | Date |
Location | (Location within VHS, eg Workshop |
Value | $$ |
#1 rule is to ALWAYS keep all clamps tightly closed while the chamber has ANY pressure inside of it, explosive decompression WILL kill you.
It's a modified paint pot and so has several valves that have been added to give a proper seal. Use the large red air compressor to pressurize.
tool/pressure_chamber.txt · Last modified: 2019/04/06 23:00 by 00739
