Name of Tool
Status | Operational as of Mar 12, 2019 |
Training | Optional |
Hackable | NO |
Usage Restrictions | Anyone |
Owner | VHS |
If it Breaks | (Panic procedure, usually involving emailing list and “broken” sign) |
Loan Status | Owned |
Arrival Date | April 2016 |
Location | Woodshop |
Value | $300 |
https://www.amazon.ca/gp/product/B012MI1G3W/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
http://powertecproducts.com/af1044-3spd-air-filtration-system-556-702-1044-cfm/
Horsepower (Maximum Developed): .1/5 HP, 120 V, 60 Hz 3 Speeds, Motor Amperage: 3A/ 2-1/2A / 2A; Motor Speeds: 750/960/1200 RPM, Air Flow: 556/702/1044-CFM, Outer Filter: 5 Micron, Inner Filter: 1 Micron, Filtration Timing: 1HR, 2HR, 4HR, Gross Weight: 73 lbs, Sound Rating @ 3 Feet: High Speed : 69dB, Medium Speed 67dB, Low Speed 62 dB
. Powerful, quiet, efficient, and potent air filtration system
. Easy to replace filter; no tools required; Outer filter: 5 micron; Inner filter: 1 micron
. 3 Air flows: 556/702/1044-CFM
. Infrared remote control system; 3 timer setting: 1hr/2hr/4hr
. Includes remote control and mounting hardware
Replacement filters:
- POWERTEC 75019 INNER FILTER FOR POWERTEC AF1044 http://powertecproducts.com/powertec-75019-inner-filter-for-powertec-af1044/
- POWERTEC 75020 OUTER FILTER FOR POWERTEC AF1044 http://powertecproducts.com/powertec-75020-outer-filter-for-powertec-af1044/
Note | Date | Who |
Wiki entry created | Mar 12, 2019 | Thomas L. |
