tool:grizzly_x3_4-axis_cnc_mill
Grizzly G0463 Mill
model Grizzly G0463 (a Seig X3)
Status Operational
Owner Richard Sim
If it Breaks Let Richard know, put up an Out of Order sign
Location Workshop
Champion Richard Sim
tool/grizzly_x3_4-axis_cnc_mill.txt · Last modified: 2019/04/07 01:46 by 54.36.148.57
