infrastructure:servers
servers [2014/07/31 17:21] – Added stub VM server description bruce | wikiattic:servers [2019/04/05 03:33] – ↷ Page moved from servers to wikiattic:servers 00739 | ||
Line 5: | Line 5: | ||
==== Virtual Servers ==== | ==== Virtual Servers ==== | ||
- | We currently | + | We currently |
- | * Home.hackspace.ca - used for projects | + | |
- | * mail.hackspace.ca - mail server and mailing lists machine | + | * krampus.vanhack.ca - mail server and membership system |
=== VHS API === | === VHS API === | ||
Line 17: | Line 17: | ||
==== Inside our Space ==== | ==== Inside our Space ==== | ||
+ | The VHS LAN uses the IP address range 172.16.0.0/ | ||
The following servers and computers have a (semi-)permanent place on the network: | The following servers and computers have a (semi-)permanent place on the network: | ||
^ Hostname | ^ Hostname | ||
- | | vhs-nanobridge | 172.16.0.2 | | | + | | pfsense.bunker.vanhack.ca | 172.16.0.1 | Routes data to the outside world | |
- | | vhs-powerstation| 172.16.0.3 | | | + | | vhs-nanobridge | 172.16.0.2 | |
+ | | vhs-powerstation| 172.16.0.3 | | ||
| vhs-cabinet | 172.16.0.7 | Solidworks/ | | vhs-cabinet | 172.16.0.7 | Solidworks/ | ||
| vhs-g61 | 172.16.0.102 | Laptop set up next to the routing/ | | vhs-g61 | 172.16.0.102 | Laptop set up next to the routing/ | ||
- | | vhs-em355 | 172.16.0.108 | | | + | | vhs-em355 | 172.16.0.108 | |
- | | vhs-5580 | 172.16.0.116 | | | + | | vhs-5580 | 172.16.0.116 | |
| vhs-doorswitch | 172.16.0.130 | Door Sensor (Raspberry Pi) | | | vhs-doorswitch | 172.16.0.130 | Door Sensor (Raspberry Pi) | | ||
| vhs-antec | 172.16.0.146 | Music/ | | vhs-antec | 172.16.0.146 | Music/ | ||
+ | | Google server | 172.16.0.245 | Vmware EXSI | | ||
=== VM Server === | === VM Server === | ||
- | VHS has a server for members to run VMs on. If you want a VM, ask on the vhs-members mailing list and someone will help you set it up. We also have a 6TB NAS server, which should hopefully provide your VM with in-space backup. | + | {{ :: |
+ | VHS has a server for members to run Virtual Machines (VMs) on. If you want a VM, ask on the vhs-members mailing list and someone will help you set it up. We also have a 6TB NAS server, which should hopefully provide your VM with in-space backup. | ||
+ | The VHS VM server also runs a PBX (Private Branch Exchange, i.e. telephone switch) for the hackspace. | ||
=== Server Policy === | === Server Policy === |
infrastructure/servers.txt · Last modified: 2019/04/06 22:44 by tyisi
