infrastructure:servers
servers [2013/07/28 04:17] – created lukec | infrastructure:servers [2019/04/06 22:44] (current) – tyisi | ||
- | == Servers and Web Resources == | + | ===== Servers and Web Resources ===== |
+ | **NOTE: Currently under revision** | ||
VHS Operates many servers inside our space and rents a few Virtual Servers for external operations. | VHS Operates many servers inside our space and rents a few Virtual Servers for external operations. | ||
- | === Virtual Servers === | + | ==== Virtual Servers |
+ | We currently have multiple virtual servers from Digital Ocean and Leaseweb. | ||
+ | * talk.vanhack.ca - used for projects, website and forums | ||
+ | * krampus.vanhack.ca - mail server and membership system | ||
+ | === VHS API === | ||
+ | VHS API is a simple HTTP interface to store values from various sensors. | ||
+ | The code is up on Github: https:// | ||
+ | ==== Inside our Space ==== | ||
+ | The VHS LAN uses the IP address range 172.16.0.0/ | ||
+ | The following servers and computers have a (semi-)permanent place on the network: | ||
+ | ^ Hostname | ||
+ | | pfsense.bunker.vanhack.ca | 172.16.0.1 | Routes data to the outside world | | ||
+ | | vhs-nanobridge | 172.16.0.2 | Does what? | | ||
+ | | vhs-powerstation| 172.16.0.3 | Does what? | | ||
+ | | vhs-cabinet | 172.16.0.7 | Solidworks/ | ||
+ | | vhs-g61 | 172.16.0.102 | Laptop set up next to the routing/ | ||
+ | | vhs-em355 | 172.16.0.108 | Does what? | | ||
+ | | vhs-5580 | 172.16.0.116 | Does what? | | ||
+ | | vhs-doorswitch | 172.16.0.130 | Door Sensor (Raspberry Pi) | | ||
+ | | vhs-antec | 172.16.0.146 | Music/ | ||
+ | | Google server | 172.16.0.245 | Vmware EXSI | | ||
+ | === VM Server | ||
- | We currently rent some virtual servers from GreenQloud, an Icelandic VPS provider. (100% Renewable energy, wooo!) | + | {{ ::server.jpg? |
- | * Home.hackspace.ca - used for projects that need to be up all the time | + | VHS has a server |
- | * mail.hackspace.ca | + | |
+ | The VHS VM server also runs a PBX (Private Branch Exchange, i.e. telephone switch) for the hackspace. | ||
- | === Inside our Space === | + | === Server Policy |
+ | All servers inside VHS are available for hacking on by all members*. | ||
- | ... Somebody add this ... | + | * Does not apply to computers that drive the laser cutter, CNC mill or other dangerous moving equipment. |
infrastructure/servers.txt · Last modified: 2019/04/06 22:44 by tyisi
