hacks:fpga:z-turn
Z-Turn
The Z-Turn IO Cape does not use the raspberry PI CSI ribbon cable interface.
Parallela porcupine uses SLW15S-1C7LF which is a 15pin 1.00mm pitch, 0.30mm - 0.33mm thinkness PCB connector.
MY-CAM011B connects to the Z-Turn IO Cape through 30-pin FPC connector.
The 30-pin FPC camera interface is defined here. I think an interface board is required to connect to a raspberry PI camera.
If you have a question for MYIR, I suggest you send TO: support@myirtech.com, sales@myirtech.com
Subject: connecting raspberry pi camera to z-turn I would like to use a raspberry pi camera with the z-turn IO cape. I would like to purchase a connector between the z-turn IO Cape J2 interface and the raspberry pi csi-2 interface. --- Subject: Re: connecting raspberry pi camera to z-turn Dear Timothy, Thanks for your mail. But I'm sorry we do not have such connectors. Please find the Z-turn IO Cape schematic enclosed
hacks/fpga/z-turn.txt · Last modified: 2017/03/28 06:32 by tdwebste
