hacks:boards:rtos:zephyr:datalogging
Zephyr Basic Data Logging
Objective
Log data from all sensors on the board to csv file.
Steps
- Setup Build Environment
- Port sensor code to Zephyr
- Write/modify code for data logging to file
- Build code
- Flash code to board
- Test
Notes
HTS221: Capacitive digital sensor for relative humidity and temperature
- Temperature (SENSOR_CHAN_TEMP, C)
- Humidity (SENSOR_CHAN_HUMIDITY, mili-percent)
I2C
- Read=10111111 (BFh)
- Write=10111110 (BEh)
LIS3MDL: High-performance 3-axis magnetometer
- Magnetometer (SENSOR_CHAN_MAGN_X, SENSOR_CHAN_MAGN_Y, SENSOR_CHAN_MAGN_Z, SENSOR_CHAN_MAGN_XYZ)
I2C
- Read= 00111101 (3Dh)
- Write=00111100 (3Ch)
LSM6DSL: 3D accelerometer and 3D gyroscope
- accelerometer (SENSOR_CHAN_ACCEL_X, SENSOR_CHAN_ACCEL_Y, SENSOR_CHAN_ACCEL_Z, SENSOR_CHAN_ACCEL_XYZ)
- gyroscope (SENSOR_CHAN_GYRO_X, SENSOR_CHAN_GYRO_Y, SENSOR_CHAN_GYRO_Z, SENSOR_CHAN_GYRO_XYZ)
- temperature (SENSOR_CHAN_TEMP - C)
I2C
- Read= 11010101 (D5h)
- Write=11010100 (D4h)
LPS22HB: 260-1260 hPa absolute digital output barometer
- pressure(SENSOR_CHAN_PRESS - kPA)
- temperature(SENSOR_CHAN_TEMP - C)
I2C
- Read= 10111011 (BBh)
- Write=10111010 (BAh)
VL53L0X: Time-of-Flight and gesture-detection sensor
- Needs to be implemented
- VL53L0X Class for mbed OS: https://os.mbed.com/teams/ST/code/X_NUCLEO_53L0A1/docs/8d27ebb4e1eb/classVL53L0X.html
- C++ for mbedOS: https://github.com/dbaba/vl53l0x-mbedos
I2C
- Read=01010011(53h)
- Write=01010010(52h)
I2C
Table 3. I2C addresses for each module
Modules Description | SAD[6:0] + R/W | I2C write address | I2C read address |
HTS221 Capacitive digital sensor for relative humidity and temperature | 1011111x | 0xBE | 0xBF |
LIS3MDL 3-axis magnetometer | 0011110x | 0x3C | 0x3D |
LPS22HB MEMS nano pressure sensor | 1011101x | 0xBA | 0xBB |
LSM6DSL 3D accelerometer and 3D gyroscope | 1101010x | 0xD4 | 0xD5 |
VL53L0X Time-of-Flight ranging and gesture detection sensor | 0101001x | 0x52 | 0x53 |
M24SR64-Y Dynamic NFC/RFID tag IC | 1010110x | 0xAC | 0xAD |
STSAFE-A100 - | 0100000x | 0x40 | 0x41 |
hacks/boards/rtos/zephyr/datalogging.txt · Last modified: 2017/10/24 20:13 by jdmc
