tool:redsail_cm1080_laser_cutter [2017/02/27 02:53] – tyisi | tool:redsail_cm1080_laser_cutter [2024/04/16 04:48] (current) – Added stepper driver details ddq | ||
Line 16: | Line 18: | ||
- | Anyone who wishes to use the laser cutter must be both a VHS member, and have completed a laser cutter training class (class dates are announced on [[http:// | ||
+ | All members using the laser cutter must have read and understand [[tool: | ||
+ | While it is important to follow all rules and guidelines, the following | ||
+ | Failure | ||
+ | Anyone who wishes to use the laser cutter must be both a VHS member, and have completed | ||
+ | Class dates are announced on [[http:// | ||
Line 26: | Line 40: | ||
- | * Controller: [[http://www.lightobject.com/ | + | * Controller: [[https:// |
- | * Chiller: [[http://vanhack.ca/doku.php? | + | * Chiller: [[https://lightobject.com/q800-water-chiller/|LightObject Industrial Water Chiller Q800]], [[https:// |
* Power supply: [[http:// | * Power supply: [[http:// | ||
* Input: AC 220V | * Input: AC 220V | ||
Line 37: | Line 52: | ||
* 3pin terminal pinout: G, AC, AC | * 3pin terminal pinout: G, AC, AC | ||
* 6pin terminal pinout: H, L, WP, G, IN, 5V | * 6pin terminal pinout: H, L, WP, G, IN, 5V | ||
+ | * Input: DC 40V | ||
+ | * Motor current: 4A | ||
+ | * Steps/rev: 5000 | ||
+ | * Idle current: half | ||
- | ==== FURTHER INFORMATION | + | ===== Usage and Maintenance ===== |
* [[committees: | * [[committees: | ||
- | * [[tool:laser_cutter: | + | * [[https:// |
- | * [[tool: | + | |
==== Tutorials ==== | ==== Tutorials ==== | ||
* [[tutorials: | * [[tutorials: | ||
- | * [[http:// | + | * [[http:// |
tool/redsail_cm1080_laser_cutter.1488164008.txt.gz · Last modified: 2017/02/27 02:53 by tyisi
