tool:redsail_cm1080_laser_cutter [2013/11/21 19:32] – jarrett | tool:redsail_cm1080_laser_cutter [2024/11/20 21:19] (current) – Added lenses link imagesurgery | ||
- | ====== Laser Cutter ====== | + | ====== |
- | Summary description of the tool and perhaps some misc notes about it's existence! | + | ---- |
- | ^ Status | + | Everybody loves lasers |
+ | * Input: AC 220V | ||
+ | * Current: 32mA max | ||
+ | * Input: DC 40V | ||
+ | * Motor current: 4A | ||
+ | * Steps/rev: 5000 | ||
+ | * Idle current: half | ||
+ | ==== Tutorials ==== | ||
+ | * [[tutorials: | ||
tool/redsail_cm1080_laser_cutter.1385062339.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
