tool:green_manual_mill
tool:green_manual_mill [2015/12/12 14:31] – external edit 127.0.0.1 | tool:green_manual_mill [2023/02/09 20:43] (current) – Corrected spindle taper to Morse MT3 androidlx | ||
====== Manual Mill ====== | ====== Manual Mill ====== | ||
- | {{:: | + | ^ Status |
- | + | ^ Training | |
- | Summary description of the tool and perhaps some misc notes about it's existence! | + | |
- | ^ Status | + | |
- | ^ Training | + | |
- | ^ Usage Restrictions | Members Only | | + | ^ Usage Restrictions | Members Only, only after VHS training / orientation |
- | ^ Owner | (VHS or Name of proper owner) | | + | ^ Owner | Mark Denny (friend |
- | ^ Value | $$ | | + | |
- | ** THERE IS NO BELT GUARD FOR THE TOP OF THE MILL. ONE NEEDS TO BE FABRICATED ** | + | Always wear eye protection while using the mill. VHS-specific training / orientation is required. If used improperly, workpieces |
- | Always wear eye protection while using the mill. Do not use the mill if you do not know how to use this type of machine. If used improperly; workpieces | + | |
===== Specifications: | ===== Specifications: | ||
- | Mill is a Long Chang LC-15A. | + | Mill is a Long Chang LC-15A. |
+ | Please review this {{ : | ||
- | Spindle Taper: | + | The following information was measured from the mill and may be inaccurate. |
+ | Spindle Taper: | ||
Table: 1/2in T slots | Table: 1/2in T slots | ||
Line 32: | Line 31: | ||
===== Notes ===== | ===== Notes ===== | ||
- | To move mill head up and down (major vertical adjustment); | + | To move mill head up and down (major vertical adjustment); |
===== Axes ===== | ===== Axes ===== | ||
Line 42: | Line 41: | ||
===== Fixtures ===== | ===== Fixtures ===== | ||
- | We have a drilling | + | The 3.5" swivel |
We have a set of 1/2in T nuts + fingers + step blocks for the CNC mill that will also fit this mill. | We have a set of 1/2in T nuts + fingers + step blocks for the CNC mill that will also fit this mill. | ||
===== Tooling ===== | ===== Tooling ===== | ||
- | - 1/4, 3/8, 1/2in collets | + | - Drill Chuck - at the moment, the only chuck key that fits is on the drill press in the Fab shop area. |
- | - Drill Chuck | + | - 2x Offset boring heads |
+ | - Fly cutter. Takes an HSS toolbit, ground to the correct profile | ||
+ | - 1/4, 3/8 and 1/2 collets. Used to hold end mills, fly cutters, and the small boring head | ||
+ | - 2.5" face mill. Needs to be replaced, as all the carbides are chipped, and are not available for purchase. Still works reasonably well | ||
+ | - Drift keys. USe to remove the tooling from the spindle. See document (pending) for use. | ||
- (many more in varying condition) | - (many more in varying condition) | ||
+ | - (Most) tooling is located in the red toolbox in the end of the (pending) work bench. | ||
+ | ===== Speeds & Feeds ===== | ||
+ | Cutting speeds can be determined easily by using this {{: | ||
- | A written tutorial won't suffice! Don't touch the machine unless you've received training | + | A written tutorial won't suffice! Don't touch the machine unless you've received training! |
Line 63: | Line 70: | ||
| Vice alined and bolted to table | Nov 26, 2013 | QuanaParker | | | Vice alined and bolted to table | Nov 26, 2013 | QuanaParker | | ||
| Tool/Work bench built {{:: | | Tool/Work bench built {{:: | ||
+ | | New drawbar, drift keys | Feb 2020 | Billiam | |
tool/green_manual_mill.1449930676.txt.gz · Last modified: 2016/04/24 07:30 (external edit)
