wiki:vhswiki:deletion [2026/06/20 12:21] – adminwiki:vhswiki:deletion [2026/09/28 10:30] (current) – admin
-<!DOCTYPE markdown>
 # Deleting Wiki Pages # Deleting Wiki Pages
-<alert info>
-[2026-05-26] This is a **[draft](https://talk.vanhack.ca/t/wiki-cleanup-updates/17057)** proposal for how to handle deleting wiki pages that no longer need to exist in order to clean up the wiki.
-</alert>
 ## Principles ## Principles
Line 32: Line 26:
 *This is a living list and may grow over time.* *This is a living list and may grow over time.*
-|Proposal Date|Proposer|Page(s) To Delete|Reason| +|Proposal Date|Proposer|Page(s) To Delete|Reason|Status|
-| 2026-05-26 | amber | [[wiki:tools:compendium_of_champions]] | No longer valid, per [notes](wiki:vhswiki:start) | +| 2026-05-26 | amber | [[wiki:tools:compendium_of_champions]] | No longer valid, per [notes](wiki:vhswiki:start) | Done. Backlinks removed. |
-| 2026-05-26 | amber | [[wiki:area]], and all subpages under it | Most useful content is covered on other pages already. Should be replaced with a single page that focuses just on the physical layout of the space as noted on [[wiki:area]] | +| 2026-05-26 | amber | [[wiki:area]], and all subpages under it | Most useful content is covered on other pages already. Should be replaced with a single page that focuses just on the physical layout of the space as noted on [[wiki:area]] | In Progress - [[wiki:space]] created as a replacement; now for incremental cleanup of pages and backlinks. |
-| 2026-05-26 | amber | [[wiki:venables]] | No longer relevant - dealt with initial setup of the Venables space, mostly links to Talk | +| 2026-05-26 | amber | [[wiki:venables]] | No longer relevant - dealt with initial setup of the Venables space, mostly links to Talk | Done. |
-| 2026-05-26 | amber | [[wiki:membership]] | Not the actual [membership page](/membership), and the info on it is outdated / incorrect | +| 2026-05-26 | amber | [[wiki:membership]] | Not the actual [membership page](/membership), and the info on it is outdated / incorrect | Done. |
-| 2026-05-26 | amber | Either [about:faq](about:faq) or [wiki:faq](wiki:faq) | Almost but not quite identical, one should be chosen to keep as the canonical FAQ and the other deleted. For the most part wiki:faq seems more up to date ([full diff](https://www.diffchecker.com/CJ4sgp9J/)). | +| 2026-05-26 | amber | Either [about:faq](about:faq) or [wiki:faq](wiki:faq) | Almost but not quite identical, one should be chosen to keep as the canonical FAQ and the other deleted. For the most part wiki:faq seems more up to date ([full diff](https://www.diffchecker.com/CJ4sgp9J/)). | Done: wiki/faq content updated and moved to about:faq, after which wiki:faq was deleted and sidebar link changed. |
-| 2026-05-26 | amber | [[wiki:do-ocracy]] [[wiki:admin:do-ocracy]] | Relatively minimal content; anything of use should just be incorporated into [the Do-ocracy section of the new member guide](wiki:vhs_member_initiation#do-ocracy) and the minimal backlinks pointed there instead |+| 2026-05-26 | amber | [[wiki:do-ocracy]] and [[wiki:admin:do-ocracy]] | Relatively minimal content; anything of use should just be incorporated into [the Do-ocracy section of the new member guide](wiki:vhs_member_initiation#do-ocracy) and the minimal backlinks pointed there instead | Done. |
 +| 2026-06-23 | amber | Either [about:code-of-conduct-grievance-procedure](about:code-of-conduct-grievance-procedure) or [wiki:admin:code_of_conduct](wiki:admin:code_of_conduct) | Duplicate versions of the Code of Conduct and the Grievance Procedure exist in these two locations; the wiki:admin version also has the VHS House Rules. We should consolidate if possible. | Proposed |
