| wiki:tools:green_manual_mill [2026/01/21 21:19] – created - external edit 127.0.0.1 | wiki:tools:green_manual_mill [2026/02/15 14:29] (current) – emile | ||
| Line 5: | Line 5: | ||
| ^ Usage Restrictions | Members Only, only after VHS training / orientation | ^ Usage Restrictions | Members Only, only after VHS training / orientation | ||
| ^ Owner | Mark Denny (friend of JohnC) | ^ Owner | Mark Denny (friend of JohnC) | ||
| - | ^ If it Breaks | + | ^ If it Breaks |
| ^ Loan Status | ^ Loan Status | ||
| ^ Arrival Date | November 2013 | | ^ Arrival Date | November 2013 | | ||
| ^ Location | ^ Location | ||
| - | ^ Champion | + | ^ Champion |
| Line 49: | Line 49: | ||
| ===== Tooling ===== | ===== Tooling ===== | ||
| - | - Drill Chuck - at the moment, the only chuck key that fits is on the drill press in the Fab shop area. | + | - Drill Chuck |
| - 2x Offset boring heads | - 2x Offset boring heads | ||
| - Fly cutter. Takes an HSS toolbit, ground to the correct profile | - Fly cutter. Takes an HSS toolbit, ground to the correct profile | ||
| - 1/4, 3/8 and 1/2 collets. Used to hold end mills, fly cutters, and the small boring head | - 1/4, 3/8 and 1/2 collets. Used to hold end mills, fly cutters, and the small boring head | ||
| - | - 2.5" | + | - face mill? |
| - | - Drift keys. USe to remove the tooling from the spindle. See document (pending) for use. | + | - Drift keys to remove the tooling from the spindle. |
| - | - (many more in varying condition) | + | |
| - | - (Most) tooling is located in the red toolbox in the end of the (pending) work bench. | + | |
| - Set of Milling Vise Parallels from KMS tools, purchased February 2025 | - Set of Milling Vise Parallels from KMS tools, purchased February 2025 | ||
| - | - 3x.5" [[https:// | + | - Lots of used carbide endmills. |
| ===== Speeds & Feeds ===== | ===== Speeds & Feeds ===== | ||
