wiki:tool [2025/11/10 00:26] – adminwiki:tool [2026/07/27 12:18] (current) – removed - external edit (Unknown date) 127.0.0.1
-====== Equipment and tools at VHS: ======
-<alert danger>
-**Many tools here can be dangerous.** If you are not qualified to use them or are unsure, please ask!
-A list of rules will not keep you safe; safety comes from knowing how to recognize all possible hazards and understanding how to deal with them.  You are responsible for your own safety and the safety of others.
-</alert>
-All dangerous tools are **members only**. Feel free to come down and use our soldering irons, hand tools, and test gear, however.
-When you add tools, please put follow [[wiki:tool:template-page|this template]]!
-See [[wiki:tool:compendium_of_champions|Compendium of Champions]] for who is in charge of the gear.
-====== 3D Printing Area ======
-See: [[wiki:area:3d-printing|3D Printing Work Area]]
-^ 3D printers  ^ Supplies  ^ Regular Printers ^
-| [[wiki:tool:voron_v2.4_voltron|Voron v2.4 350mm: Voltron]] | [[wiki:tool:3d_filament|3D Printing Filaments]] | [[wiki:tool:HP LaserJet Pro 400]] |
-| [[wiki:tool:jube_jubes |Jube Jubes Prusa MK3S]] | [[wiki:tool:glue|Glues]] |
-| [[wiki:tool:brian |Brian Prusa MK3S]] | [[wiki:tool:3d_printing_resin|3D Printing Resin]] |
-| [[wiki:tool:sovol-sv08 |Sovol SV08]]|
-| [[wiki:tool:Form1SLA|Form 1]] |
-| [[wiki:tool:Vaquform DT2|Vaquform DT2 Vaccuformer]] | |
-^ Loaner 3D printers ^ Model ^
-| [[wiki:tool:DittoPro|Tinkerine Ditto Pro]] |
-^ SLA Printers (Resin) ^ Model ^
-| [[wiki:tool:3d-printers:AnyCubic Photon Mono]] | Photon Mono (small)|Photon Mono (small)|
-| [[wiki:tool:3d-printers:AnyCubic Photon Mono X | Mono X (medium)]] | Mono X (medium) |
-| [[wiki:tool:3d-printers:AnyCubic Photon M3 Max | M3 Max (Large)]] | M3 Max (Large) |
-====== Arts and Crafts ======
-See: [[wiki:area:crafting|Arts and Crafts Area]]
-===== Sewing =====
-^ Machines ^ Tools ^ Supplies  ^ Misc ^
-| [[wiki:tool:Sewing Machines]] | [[wiki:tool:Cutting Table]] | [[wiki:tool:pattern_paper|Pattern Paper Roll]] | Mini Library |
-| [[wiki:tool:sewing_machines#VHS_sergers|Overlock sergers]] | [[wiki:tool:Silkscreening]] | Donated Fabric| Peg Board |
-| [[wiki:tool:ironing|Irons + Ironing Boards]] | [[wiki:tool:ironing#Dress_Form|Dress Form]] | Thermoplastic / Worbla | Pattern Weights |
-| [[wiki:tool:ironing#Conair_Steamer|Conair Steamer]] |  | Notions | Thread Rack |
-| [[wiki:tool:relsew4000sw|Industrial Walking Foot]] | [[wiki:tool:overhead_projector|Overhead Projector]]  | | |
-===== Art =====
-^ Machine ^ Tools ^ Supplies ^ ^ ^
-| [[wiki:tool:vinyl_cutter|Vinyl Cutter]] | Sculpting Tools | Origami paper | Stamps | Sidewalk chalk |
-| [[wiki:tool:Badge a Minit Button Maker|Button Maker]] | Wood Burning Kit | Jewelry supplies and beads | Stamp ink | Markers |
-|  | Paint and sponge brushes | Paint (watercolour, acrylic) | Balsa wood | Pencil crayons / pastels |
-|  | Exacto Knife kit | Ribbons and string | pom-poms | leather scraps |
-====== CNC Area ======
-See: [[wiki:area:metal_shop|Machine Shop]]
-^ Stationary Machines ^ Portable Tools ^ Tools ^ Supplies ^
-| [[wiki:tool:Drill Press]] | Shopvac (shared with Machine Shop) | Hand Tools | Safety Equipment |
-| [[wiki:tool:Grizzly X3 4-Axis CNC Mill|CNC Mill "Gage"]] | | CNC Tool Library (WIP) | Flux |
-| [[wiki:tool:jaxen_cnc_mill|CNC Mill "Jaxen"]] | | | |
-| [[wiki:tool:6040 CNC Mill|6040 CNC Mill "Loratron"]] | | | |
-| [[wiki:tool:fasteners|Nuts, Bolts, Screws, Washers...]] | | | |
-====== Electronics ======
-See: [[wiki:area:electronics|Electronics Area]]
-^ Soldering Equipment  ^ Electronic Test Equipment  ^ Misc Equipment   ^ tools ^ Supplies ^
-| [[wiki:tool:Soldering Stations]] | [[wiki:tool:Digital Multimeters (DMMs)]] | [[wiki:tool:oscillator_model_k8202_400v_ac_power_supply| 400v power supply]] | [[wiki:tool:Terminal Crimper]] and ring terminals | [[wiki:tool:Solder]] |
-| [[wiki:tool:Inspection Microscope]] | [[wiki:tool:Oscilloscopes]] | [[wiki:tool:voltbox_ac_power_supply| Voltbox AC Power Supply]] | [[wiki:tool:Battery Spot Welder]] | [[wiki:tool:Solder Wick]] |
-| [[wiki:tool:Hot Air Station]] | [[wiki:tool:Power Supplies]] | [[wiki:tool:powerbright_vc-750w_step_up_down_transformer| Powerbright vc-750w transformer]] |  |Flux |
-| [[wiki:tool:Third Hands]] | [[wiki:tool:Logic Analyzer]] |  |  | Copper tip cleaner |
-| [[wiki:tool:Panavise Junior]] | [[wiki:tool:Variac]] |  |  | Tweezers |
-| [[wiki:tool:SMD Reflow Oven]] | [[wiki:tool:Function Generator]] |  |  | Cleaning Brushes |
-| [[wiki:tool:Infrared IC Heater]] | [[wiki:tool:Rigol MSO1074Z]] |  |
-| [[wiki:tool:Hakko Omnivise PCB Holder]] |  |  |
-| [[wiki:tool:Essemtec PCB Oven]] | | |
-| [[wiki:tool:Essemtec Pick and Place]] | | |
-|.[[wiki:tool:Essemtec Stencil Screen Printer]] | | |
-====== Kitchenette ======
-See: [[wiki:area:kitchenette|Kitchenette]]
-^ Machines ^ Supplies ^
-| [[wiki:tool:refrigerator]] |  |
-| [[wiki:tool:coffee_machine|Coffee Machine]] | Cups |
-| [[wiki:tool:hot plate]] | [[wiki:tool:Brewing Equipment]] |
-| [[wiki:tool:Convection Oven]] |
-====== Laser Cutter ======
-See: [[wiki:area:lasercutroom|Laser Cutting Area]]
-| [[wiki:tool:RedSail CM1080 Laser Cutter]] | [[wiki:area:material_storage|Laser cutter material storage]] |
-| [[wiki:tool:laserfilter|Laser cutter filtration system]] | [[wiki:tool:laser_cutter:settings|Approved Laser Cutter Materials]] |
-====== Machine Shop ======
-| [[wiki:tool:Green Manual Mill]] | [[wiki:tool:Welder|Millermatic 211 MIG Welder]] | Hand Tools | Safety Equipment |
-| [[wiki:tool:manual_lathe|Metal Lathe]] | [[wiki:tool:PowerTIG250EX|PowerTIG 250EX Welder]] | [[wiki:tool:Norseman Drill Bit Set]] | [[wiki:tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
-| [[wiki:tool:Bench Bandsaw]] | | [[wiki:tool:measuring_tools]] |
-| [[wiki:tool:Horizontal Bandsaws]] | |
-====== Maintenance/Facility ======
-^ Machines ^
-| [[wiki:tool:woodshop_dust_extraction_automation_system|Woodshop Dust Extraction Automation System]] |
-| [[wiki:tool:powertec_air_filter|POWERTEC AF1044 3SPD Air Filtration System]] |
-| [[wiki:tool:transformer|Power Transformer 20kVA 240V Delta to 120/208V Wye ]] |
-| [[wiki:tool:Air Compressor|Campbell Hausfeld Air Compressor (tank is still in use)]] |
-| [[wiki:tools:Boge Air Compressor|Boge Air Compressor]] |
-====== Metal Shop ======
-See: [[wiki:area:welding|Metal Shop]]
-| Box and Pan Brake | [[wiki:tool:Welder|Millermatic 211 MIG Welder]] | Hand Tools | Safety Equipment |
-| Welding Table | [[wiki:tool:PowerTIG250EX|PowerTIG 250EX Welder]] | | Flux |
-| [[wiki:tool:manual_lathe|Metal Lathe]] | [[wiki:tool:Bosch 4.5" Angle Grinder]] | | [[wiki:tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
-| [[wiki:tool:Bench Grinder]] | [[wiki:tool:Cut-Off Saw]] |  | Donated metal |
-| [[wiki:tool:Green Manual Mill]] | [[wiki:tool:18.0V Cordless Drill]] |
-| [[wiki:tool:Bench Bandsaw]] | [[wiki:tool:Plasma Cutter]] |
-| [[wiki:tool:Horizontal Bandsaws]] | [[wiki:tool:Ring Roller]] |
-| [[wiki:tool:Scroll Saw]] | [[wiki:tool:tube_bender]] |
-| [[wiki:tool:Buffing Machine]] |
-| [[wiki:tool:Blacksmith forge and anvil]] |
-| [[wiki:tool:Heat Treating Oven]] |
-===== Ops Room =====
-See: [[wiki:area:ops_room|Ops Room]]
-^ Servers ^
-| [[wiki:tool:server_rack|Server Rack]] |
-| [[wiki:infrastructure:servers#space|Infrastructure Servers]] |
-| [[wiki:tool:fpga-cluster|FPGA Cluster]] |
-====== Paint & Mess Room ======
-^ Tools               ^ Software     ^
-| [[wiki:tool:pressure_chamber|Pressure Chamber]] | [[wiki:tutorials:vhs_solidworks|SolidWorks]] |
-| [[wiki:tool:vacuum_chamber|Vacuum Chamber]] | [[wiki:tutorials:fusion360|Fusion 360]] |
-| [[wiki:tool:acrylic_bender|Acrylic Bender]] |  |
-| [[wiki:tool:vacuum_investment_casting_machine|Vacuum Investment Casting Machine]] |  |
-====== The Hangout ======
-See: [[wiki:area:the_hangout|The Hangout]], [[wiki:area:ops_room|Ops Room]], [[wiki:area:Leopard_room|Leopard Room]], [[wiki:Area:washrooms|Washrooms]]
-^ Machines ^ Supplies ^ misc ^
-| [[wiki:tool:Industrial Arm]] | [[wiki:tool:officesupply|Office supplies]] | [[wiki:tool:admincabinet|Admin Cabinet]] |
-| [[wiki:tool:Mini-fridge]] | [[wiki:tool:Keggerator]] | [[wiki:tool:labelingsupplies|Brother QL-570 Label Printer]] | [[wiki:tool:arcademachine|Arcade Machine]] |
-| [[wiki:tool:Chromecast|Chromecast TV and Speakers]] | [[wiki:tool:labelingsupplies#box of label strips|Labeling supplies]] | [[wiki:hacks:led_wall|LED Wall]] |
-| [[wiki:tool:ultrasonic_cleaner|Ultrasonic Cleaner]] | [[wiki:tool:cleaning_supplies|Cleaning supplies]] | [[wiki:tool:social_buttons|VHS Social Buttons]] |
-| [[wiki:tool:Microwave]] |
-| [[wiki:tool:Video Wall]] |
-====== Woodworking ======
-See: [[wiki:area:Wood_shop|Wood Shop]]
-| [[wiki:tool:Wood CNC]] | [[wiki:tool:Thickness Sander]] | hand tools | [[wiki:tool:glue|Glues]] |
-| [[wiki:tool:Drill Press]] | [[wiki:tool:Random-Orbit Palm Sander]] | [[wiki:tool:wood steamer|Wood Steamer]] | [[wiki:tool:fasteners|Nuts, Bolts, Screws, Washers...]] |
-| [[wiki:tool:Bench Bandsaw]] | [[wiki:tool:18.0V Cordless Drill]] | [[wiki:tool:Norseman Drill Bit Set]] |  |
-| [[wiki:tool:Scroll Saw]] | [[wiki:tool:Jointer]] | [[wiki:tool:French Cleat Wall]] |  |
-| [[wiki:tool:Table Saw]] | [[wiki:tool:Cut-Off Saw]] |
-| [[wiki:tool:Mini Wood (Pen) Lathe]] | [[wiki:tool:Planer 40200H]] |
-| [[wiki:tool:Small Wood Lathe]] | [[wiki:tool:7-1_4-inch_circular_saw|7-1/4-inch Circular Saw]] |
-| [[wiki:tool:Bernie the Spindle Sander]] | [[wiki:tool: 14" Bandsaw]]  |
-| [[wiki:tool:Bosch Miter Saw]] |[[wiki:tool:Milwaukee Track Saw]]  |
-| [[wiki:tool:Hammer Jointer/Planer]] |
-| [[wiki:tool:Ridgid 4 Gallon Portable Vacuum]] |  |
-| [[wiki:tool:Magnum Industrial Dust Collector]] | [[wiki:tool:Dremel Vibrating Multi Tool]]  |
-====== Retirement ======
-[[wiki:area:Retirement|Candidates for Retirement]] \\
-[[wiki:area:Retired Equipment]]
