wiki:tool:laser_cutter:settings [2025/05/20 08:04] – created - external edit 127.0.0.1wiki:tool:laser_cutter:settings [2026/08/17 05:57] (current) – removed - external edit (Unknown date) 127.0.0.1
-====== VHS Laser Cutter Approved Materials ======
-Only the following materials may be cut or engraved on the [[tool:redsail_cm1080_laser_cutter|VHS Laser Cutter]]. If the material you wish to cut is not listed, please see: [[tool:laser_cutter:MSDS|How do I get a new material approved?]]
-Settings are provided here as a starting point. Always do test cuts to find optimal settings.
-===== Papers =====
-^ Material ^ Mode ^ Speed ^ Power ^ Corner Power ^ Passes ^ Notes ^
-| Card Stock | Etch | 35 | 10 | 10 | 1 |    |
-| Card Stock | Cut | 35 | 35 | 25 | 1 |    |
-| Heavy paper | Cut | 200 | 20 | 20 | 1 | Worked barely; long straight cuts needed multiple passes, and a few corners were missed. Use lower speed |
-| Picture Matting | Cut | 40 | 50 | 40 | 1 |    |
-| Corrugated Cardboard | | | | | | |
-===== Woods =====
-Please avoid the use of woods with any water, sap, or a high proportion of glue. They quickly clog the filtration system and leave substantial residue on the laser cutter.
-| Plywood 1/4" Birch | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$50 for 8'x4' |
-| Plywood 1/8" Birch | Cut | 24 | 55 | 55 | 1 | From Windsor Plywood ~$17 for 5'x5' |
-| Plywood 1/8" Maple| Cut | 24 | 55 | 55 | 1 | |
-| Plywood 1/8" Birch | Etch | 80 | 28 | 28 | 1 | Deep etching, excellent for countersinking screw holes |
-| Plywood 4.2mm FSC Virola | Cut | 40 | 50 | 45 | 2 | From Home Depot ~$20 for 8'x4' SKU 1000-125618 (Tom)|
-| Plywood 1/4" Flooring underlay | Cut | 12 | 60 | 60 | 1 | From Home Depot ~$9 for 4'x4' |
-===== Plastics =====
-| Acrylic - 1/4" (6mm) | Cut | 20 | 40 | 40 | 1 |    |
-| Acrylic - 1/16" (1.5mm) | Cut | 25 | 30 | 30 | 1 |    |
-| Acrylic - 3/16" (4.5mm)   | Cut   | 20   | 35   | 35   | 1  |
-| Acrylic - 1/8" (3mm)   | Cut   | 25   | 35   | 35   | 1  |
-| Polypropylene (0.75mm) | Cut | 30 | 50 | 45 | 1 | From Yoko-yaya, ideal for painting stencils (John) |
-| EVA Foam (very thin, < 4mm) | Cut | | | | 1 | Michaels |
-| EVA Foam (thin, ~1/4") | Cut | | | | 1 | Bought online, could not find locally |
-| EVA Foam (thick, 1/2" floor mats) | Cut | 30 | 50 | 50 | 1 | Canadian Tire, Home Depot, etc. |
-| PET/PETG (e.g. Mylar(tm) ) | Cut | | | | 1 |  |
-| PET/PETG (1/16") | Cut | 30 | 45 | | 1 | From Associated Plastics |
-| Kapton Polyimide Film | | | | | | [[http://wcam.engr.wisc.edu/Public/Safety/MSDS/Kapton%20Polyimide%20Film%20-%20Dupont.pdf|MSDS]] |
-| Styrene - 2mm | Cut | | | | 1 | 2mm white styrene sheet from hobby stores   |
-| Kaizen Foam | Cut | | | | 1 |    |
-===== Fabric =====
-| Leather (Vegetable Tanned) | Cut | | | | 1 |  |
-| Felt | Cut | 100 | 25 | | 1 |    |
-===== Other =====
-| Application Tape | | | | | | Small amounts used for masking |
-| Painters Tape | | | | | | Small amounts used for masking |
-| Laserbond100 Marking Spray | | | | | | Aerosol propellants are nasty - ensure the coating has fully dried before lasering |
-| Cermark 6000 Marking Spray | | | | | | Aerosol propellants are nasty - ensure the coating has fully dried before lasering |
-| Rustoleum Painters Touch Spray Paint | | | | | | Aerosol propellants are nasty - ensure the coating has fully dried before lasering \\ [[https://www.rustoleum.com/MSDS/ENGLISH/249127.pdf|MSDS]]|
-| Krylon Dual Superbond Paint + Primer Gloss Black | | | | | | Aerosol propellants are nasty - ensure the coating has fully dried before lasering \\ [[https://static.globalindustrial.com/products/pdf/17063_krylon/B1400034_K08820001-KR-English-SDS-US-22May2019.pdf|MSDS]]|
-===== Etch Only =====
-| Anodized Aluminum| Vector Etch | | | | 1 |
-====== Banned Materials ======
-The following is a non-exhaustive list of materials that must not be cut or engraved on the [[tool:redsail_cm1080_laser_cutter|VHS Laser Cutter]].
-^ Material ^ Reason ^
-| Wet or 'raw' wood             | Clogs up filter BADLY |
-| MDF, HDF, Ply, and reconstructed wood  | Clogs up filter BADLY |
-| Coroplast                     | Clogs up filter BADLY |
-| Lexan/Polycarbonate/Makrolon | Dense black smoke and toxic fumes - bisphenol a (BPA), phenol, and more |
-| ABS | Dense black smoke and toxic fumes - cyanide and styrene gases |
-| PVC, Vinyl    | Toxic and corrosive fumes - chlorine gas |
-| Neoprene (polychloroprene) | Toxic and corrosive fumes - chlorine gas |
-| Foam core | Dense black smoke and toxic fumes - styrene gas (carcinogenic, toxic to the nervous system and upper respiratory tract; classified as "very toxic") |
-| Delrin | Toxic fumes - formaldehyde |
-| Moleskine notebook covers | Toxic fumes - chlorine - See Polymer burnination link at bottom|
-| Carbon Fiber | Hazardous dust |
-| Fiberglass | Hazardous dust |
-| Printed Circuit board | Hazardous dust |
-| Chrome Tanned Leather | Toxic/hazardous fumes |
-====== Provisionally Approved ======
-The following materials have been provisionally approved by the Laser Cutter Committee for testing:
-| Cork | Cut | TBD | TBD | TBD | TBD |    |
-| Cork | Etch | TBD | TBD | TBD | TBD |    |
-====== FURTHER INFORMATION ======
-  * [[tool:redsail_cm1080_laser_cutter|Redsail CM1080 Laser Cutter]]
-  * [[tool:laser_cutter:operation_manual|Operation Manual]]
-  * [[tool:laser_cutter:workflow_tips|General Workflow Tips]]
-  * [[http://www.adafruit.com/blog/?p=16409|Determining Kerf]]
-  * [[https://vanhack.ca/doku.php?id=tool:laser_cutter:identifying_unknown_polymers|Identifying Unknown Polymers]] -  **READ THIS BEFORE CUTTING UNKNOWN MATERIALS**
-  * [[http://www.pololu.com/docs/0J24/3|Pololu banned materials list]] - Some of their allowable settings are different because they have a different(read: expensive) fume/ventilation system
