wiki:tech [2026/02/12 12:10] adminwiki:tech [2026/02/12 12:11] (current) admin
Line 9: Line 9:
 - Advanced DokuWiki plugin - Installed to allow editing config files not otherwise available in the UI - may not be needed. - Advanced DokuWiki plugin - Installed to allow editing config files not otherwise available in the UI - may not be needed.
 - Bureaucracy Plugin - enables the [contact form](/contact-us). - Bureaucracy Plugin - enables the [contact form](/contact-us).
-- Commonmark Plugin - put `<!DOCTYPE markdown>` at the top of a page to enable markdown syntax+- Commonmark Plugin - put `<!DOCTYPE markdown>` at the top of a page to enable [markdown syntax](https://commonmark.org/help/)
 - folded plugin - installed but disabled, lets you make folding sections - folded plugin - installed but disabled, lets you make folding sections
 - Meta plugin - used to set the page title, when we want it to be something other than the first heading on the page. used on the [Home page](/start). - Meta plugin - used to set the page title, when we want it to be something other than the first heading on the page. used on the [Home page](/start).
