wiki:groups:lasercutter:settings [2026/03/21 14:08] ddqwiki:groups:lasercutter:settings [2026/05/24 23:14] (current) – fix wikilinks amber
 ====== VHS Laser Cutter Approved Materials ====== ====== VHS Laser Cutter Approved Materials ======
-Only the following materials may be cut or engraved on the [[wiki:tools:redsail_cm1080_laser_cutter|VHS Laser Cutter]]. If the material you wish to cut is not listed, please see: [[wiki:tools:laser_cutter:MSDS|How do I get a new material approved?]]+Only the following materials may be cut or engraved on the [[wiki:tools:redsail_cm1080_laser_cutter|VHS Laser Cutter]]. If the material you wish to cut is not listed, please see: [[wiki:groups:lasercutter:MSDS|How do I get a new material approved?]]
 Settings are provided here as a starting point. Always do test cuts to find optimal settings. Settings are provided here as a starting point. Always do test cuts to find optimal settings.
Line 90: Line 90:
   * [[wiki:tools:redsail_cm1080_laser_cutter|Redsail CM1080 Laser Cutter]]   * [[wiki:tools:redsail_cm1080_laser_cutter|Redsail CM1080 Laser Cutter]]
-  * [[wiki:tools:laser_cutter:operation_manual|Operation Manual]] +  * [[wiki:groups:lasercutter:operation_manual|Operation Manual]]
-  * [[wiki:tools:laser_cutter:workflow_tips|General Workflow Tips]]+  * [[wiki:groups:lasercutter:workflow_tips|General Workflow Tips]]
   * [[http://www.adafruit.com/blog/?p=16409|Determining Kerf]]   * [[http://www.adafruit.com/blog/?p=16409|Determining Kerf]]
   * [[https://vanhack.ca/doku.php?id=tool:laser_cutter:identifying_unknown_polymers|Identifying Unknown Polymers]] -  **READ THIS BEFORE CUTTING UNKNOWN MATERIALS**   * [[https://vanhack.ca/doku.php?id=tool:laser_cutter:identifying_unknown_polymers|Identifying Unknown Polymers]] -  **READ THIS BEFORE CUTTING UNKNOWN MATERIALS**
   * [[http://www.pololu.com/docs/0J24/3|Pololu banned materials list]] - Some of their allowable settings are different because they have a different(read: expensive) fume/ventilation system   * [[http://www.pololu.com/docs/0J24/3|Pololu banned materials list]] - Some of their allowable settings are different because they have a different(read: expensive) fume/ventilation system
