| wiki:groups:lasercutter:laser_focus_lens_focal_length [2026/08/07 12:30] – phb | wiki:groups:lasercutter:laser_focus_lens_focal_length [2026/09/28 10:26] (current) – admin | ||
| Line 1: | Line 1: | ||
| Understanding laser focus will help you reason about difficulties that you are having with cutting your material. Here is a diagram of a general lens mfor a laser cutter: | Understanding laser focus will help you reason about difficulties that you are having with cutting your material. Here is a diagram of a general lens mfor a laser cutter: | ||
|  scrap of wood material and a wooden block. Place the short piece on the block to create a ramp: | ||
| + | ![Ramp test](https:// | ||
| + | Without disturbing the position of the material, use the focus guide to determine whether your material needs to be adjusted. You can estimate the size of the laser focus spot using the ramp, either in your mind by guesstimating the thickness of your material, or precisely by measuring the angle of your ramp: | ||
