vhs_member_initiation
vhs_member_initiation [2019/04/12 19:53] – 00739 | vhs_member_initiation [2019/04/18 23:33] – 00739 | ||
- | ====== How Hackspaces Work ====== | + | ====== How Hackspaces Work (and VHS In Particular) ====== |
Line 19: | Line 18: | ||
- | * Bathrooms | + | |
* The phone | * The phone | ||
Line 28: | Line 26: | ||
Once you've got that down, take some time and make sure you are familiar with | Once you've got that down, take some time and make sure you are familiar with | ||
- | * The [[admin:codes_of_conduct|Code of Conduct]] | + | * The [[admin:safety|Code of Conduct]] |
* How to use the [[tool: | * How to use the [[tool: |
vhs_member_initiation.txt · Last modified: 2019/04/20 22:25 by 00739
