tutorials:making_a_filament_pulley_or_hobbed_bolt
tutorials:making_a_filament_pulley_or_hobbed_bolt [2014/07/14 01:22] – ashley | tutorials:making_a_filament_pulley_or_hobbed_bolt [2014/07/14 05:14] – ashley | ||
Line 7: | Line 7: | ||
>> Insert Dan's pictures << | >> Insert Dan's pictures << | ||
- | Next, we placed the bolt into the [[http:// | + | Next, we placed the bolt into the [[http:// |
Line 19: | Line 19: | ||
*Use M8 bolts if possible so they fit standard 608ZZ bearings. The 5/16 bolts were a bit loose. | *Use M8 bolts if possible so they fit standard 608ZZ bearings. The 5/16 bolts were a bit loose. | ||
*We had some concern about the 3D printed jigs but they were very strong, printed in PET at 100% infill. | *We had some concern about the 3D printed jigs but they were very strong, printed in PET at 100% infill. | ||
- | *The Tantillus would benefit from having a shorter, Wades' style bolt. They are easier to cut because the teeth are near the centre allowing the cut to happen inside the jig instead of outside, | + | *The Tantillus would benefit from having a shorter, Wades' style bolt. They are easier to cut and easy to source ready-made. |
tutorials/making_a_filament_pulley_or_hobbed_bolt.txt · Last modified: 2015/12/12 14:31 by 127.0.0.1
