tutorials:laser-etching
tutorials:laser-etching [2015/12/12 14:31] – external edit 127.0.0.1 | tutorials:laser-etching [2017/06/28 18:53] (current) – jarrett | ||
- | This tutorial is a work in progress and will be updated as I get more screenshots and images. | + | This tutorial is a work in progress and will be updated as I get more screenshots and images. |
The purpose of this tutorial is to walk you through the steps required to convert a full color image into something the laser cutter can work with to etch the image. | The purpose of this tutorial is to walk you through the steps required to convert a full color image into something the laser cutter can work with to etch the image. | ||
Line 95: | Line 95: | ||
* **Experiment**: | * **Experiment**: | ||
+ | * **Hyperdither**: |
tutorials/laser-etching.txt · Last modified: 2017/06/28 18:53 by jarrett
