tool:weller_wes51_temperature_controlled_soldering_stations
tool:weller_wes51_temperature_controlled_soldering_stations [2013/11/21 21:19] – created jarrett | tool:weller_wes51_temperature_controlled_soldering_stations [2016/06/06 16:52] (current) – Added Jon's note about soldering tips bruce | ||
Line 8: | Line 8: | ||
* **arrived** = Dec 2011 | * **arrived** = Dec 2011 | ||
* **does it work?** = Works | * **does it work?** = Works | ||
- | * **if it breaks** = Unplug machine, put a "broken& | + | * **if it breaks** = Unplug machine, put a "broken" |
* **contact** = VHS email list | * **contact** = VHS email list | ||
* **where** = Above the electronics test area | * **where** = Above the electronics test area | ||
Line 16: | Line 16: | ||
====== Operation Details ====== | ====== Operation Details ====== | ||
+ | WES51 irons work with Weller "ET Series" | ||
This is one of the better videos about soldering: | This is one of the better videos about soldering: | ||
http:// | http:// | ||
tool/weller_wes51_temperature_controlled_soldering_stations.1385068751.txt.gz · Last modified: 2015/12/12 14:31 (external edit)
