tool:weller_wes51_temperature_controlled_soldering_stations
Next revision | Previous revisionLast revisionBoth sides next revision | ||
tool:weller_wes51_temperature_controlled_soldering_stations [2013/11/21 21:19] – created jarrett | tool:weller_wes51_temperature_controlled_soldering_stations [2015/12/12 14:31] – external edit 127.0.0.1 | ||
Line 8: | Line 8: | ||
* **arrived** = Dec 2011 | * **arrived** = Dec 2011 | ||
* **does it work?** = Works | * **does it work?** = Works | ||
- | * **if it breaks** = Unplug machine, put a "broken& | + | * **if it breaks** = Unplug machine, put a "broken" |
* **contact** = VHS email list | * **contact** = VHS email list | ||
* **where** = Above the electronics test area | * **where** = Above the electronics test area |
tool/weller_wes51_temperature_controlled_soldering_stations.txt · Last modified: 2016/06/06 16:52 by bruce
