tool:voron_v2.4_voltron
Voltron: Voron v2.4 350mm
| Status | Under construction |
| Training | Mandatory (Unique to this printer) |
| Hackable | No |
| Usage Restrictions | See Below |
| Owner | VHS |
| If it Breaks | Put a “broken” sign on machine, post to Talk with details. |
| Loan Status | n/a |
| Arrival Date | Jan 2024 |
| Location | 3D Printing Bench |
Features
- 350mm × 350mm × 350mm build volume
- Mosquito Hotend with Diamondback hardened nozzle
- Removable spring steel build plate
- Compatible materials*: PLA, PETG, TPU
- Wonky googly eyes
- No Start/End gcode required
- Automatic bed levelling and Z offset
- (tbd) External ventilation
*Not an exhaustive list; contact #3D Printer Committee by posting on Talk to request using other materials.
Information
Added to the 3D printing stable in 2024, the Voron is VHS's first high-speed, larger size, enclosed printer. It is named Voltron, and uses the pronouns 'They/Them/It'.
Currently, it is still under construction. Once ready for members, it will require a separate training session to cover all of the info which is unique to this printer at VHS. To get training, post on Talk requesting a session.
More info will be added shortly!
Maintanance and Build Information
tool/voron_v2.4_voltron.txt · Last modified: 2024/08/13 03:36 by imagesurgery
