tool:vinyl_cutter
tool:vinyl_cutter [2017/12/14 21:31] – hughl87 | tool:vinyl_cutter [2019/07/04 06:32] – mimi_x | ||
Line 56: | Line 56: | ||
Chances are the blade is dull and you won't get a very good cut. To replace the blade, open the bracket on the traveling cut head and remove the cylindrical part. Unscrew the top to get at the blade. Don't lose any of these parts! | Chances are the blade is dull and you won't get a very good cut. To replace the blade, open the bracket on the traveling cut head and remove the cylindrical part. Unscrew the top to get at the blade. Don't lose any of these parts! | ||
- | Searching AliExpress or eBay for " | + | We now have two different |
+ | Since the 2mm blades are much more common and easier to come by, there is almost no reason to use the 2,5 mm holder. | ||
- | Common blades are 2mm diameter but our blade holder requires 2.5mm blades. A 2mm will sort of work, but with significant slop. | ||
=== Blade Angle === | === Blade Angle === | ||
- | According | + | According |
<WRAP center round box 85%> | <WRAP center round box 85%> | ||
Line 127: | Line 130: | ||
==== More info ==== | ==== More info ==== | ||
tool/vinyl_cutter.txt · Last modified: 2021/04/26 14:21 by nich
