tool:vacuum_chamber
Both sides previous revisionPrevious revision | Last revisionBoth sides next revision | ||
tool:vacuum_chamber [2016/06/16 20:59] – mike_taylor | tool:vacuum_chamber [2019/04/06 23:01] – 00739 | ||
====== Vacuum Chamber ====== | ====== Vacuum Chamber ====== | ||
- | Located in the machine shop on the large shelf. It has a dedicated vacuum pump attached to the lid. | + | ^ Status |
+ | ^ Usage Restrictions | (Anyone, Members Only, Keyholders Only, Whitelist) | ||
+ | ^ Owner | (VHS or Name of proper owner) | ||
+ | ^ Arrival Date | Date | | ||
+ | ^ Value | $$ | | ||
+ | ===== Safety ===== | ||
+ | This should outline safety concerns and guidelines for the tool and it's operation. | ||
+ | ===== Specifications ===== | ||
+ | It has a dedicated vacuum pump attached to the lid. | ||
+ | ===== Tutorial ===== | ||
Usage is pretty simple, ensure a good seal of the lid, and pull the air out using the vacuum pump. The valves point toward the direciton of airflow, you want to open the valve to the pump and close the valve to the outside while pulling. | Usage is pretty simple, ensure a good seal of the lid, and pull the air out using the vacuum pump. The valves point toward the direciton of airflow, you want to open the valve to the pump and close the valve to the outside while pulling. |
tool/vacuum_chamber.txt · Last modified: 2020/11/30 23:18 by johnc
