tool:thickness_sander
tool:thickness_sander [2023/02/02 15:28] – phillip_ma | tool:thickness_sander [2023/02/02 15:33] – phillip_ma | ||
Line 53: | Line 53: | ||
* Watch some videos on Youtube about how to use a thickness sander | * Watch some videos on Youtube about how to use a thickness sander | ||
- | * Start with a pass where you aren't sanding anything so that you know you aren't cutting too deep and progress it no more than a 1/8th turn each time a 16th or . | + | * Start with a pass where you aren't sanding anything so that you know you aren't cutting too deep and progress it no more than a 16th of a turn. |
* Don't stand directly behind the piece similar to a planer or table saw | * Don't stand directly behind the piece similar to a planer or table saw | ||
* Before using, make sure the drum has the sandpaper securely attached and the sandpaper is clean, if the sandpaper isn't clean, use the crepe block. | * Before using, make sure the drum has the sandpaper securely attached and the sandpaper is clean, if the sandpaper isn't clean, use the crepe block. | ||
Line 86: | Line 86: | ||
| Drive belt for sanding Drum replaced since it broke, Beveled gears controlling lift mechanism replaced with steel gears. | | Drive belt for sanding Drum replaced since it broke, Beveled gears controlling lift mechanism replaced with steel gears. | ||
| Motor for the conveyor belt repaired. | | Motor for the conveyor belt repaired. | ||
+ | | Motor for the conveyor belt seized again shortly after it was reinstalled. | ||
